3 Prong Outlet To 2 Wire System?? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 05:46 PM   #1
3 prong outlet to 2 wire system??
Our house was built in 1949 and only has 2 wire throughout the house. I see the PO has 3 prong outlets in a few and the are not grounded. There is no way to ground those because the box is simply nailed to the studs. Is this compliant? Any issues with doing this (safety etc)?
smawgunner is offline   Reply With Quote
Old 01-22-2011, 06:17 PM   #2
Receptacles in homes wired without grounding can have receptacles replaced with GFCI receptacles.
Its not necessary to replace all the recpts. as any outlets that are wired 'down stream' from GFCI recpts. are protected also.
Old 01-24-2011, 11:38 AM   #3
WaldenL's Avatar
Rewards Points: 268
However, those receptacles still aren't "grounded." Yes, it's a hell of a lot safer with the GFCI, but don't expect an equipment ground to work. Ideally the ungrounded 3-prong receptacles should be marked as ungrounded.
WaldenL is offline   Reply With Quote
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Wire recessed light from a 3 prong receptacle? prc114 Electrical 9 12-22-2009 10:29 AM
Four wire to exterior outlet? ElsReverie Electrical 5 10-19-2009 02:32 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
dryer Outlet change 3 prong to 4 prong oldpirate General DIY Discussions 2 08-06-2008 07:18 PM
