3 Prong Dryer To 4 Prong Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 11:03 PM   #1
3 prong dryer to 4 prong issue
Hey guys,
I am changing a 3 prong dryer cord to a 4 prong cord.
There is no bonding jumper.
Instead there is a green wire that is attached by a screw to the frame.
If I follow this green wire back it attaches to the white "nuetral" wire like I think I should expect.
I need to attach the new green "ground wire" for the new 4 prong cord...
...but what do I do with the previous green wire that is in its spot?
Please help.
Thank you.
KC
titan is offline   Reply With Quote
Old 03-06-2011, 11:27 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by titan View Post
Hey guys,
Please help.
Thank you.
KC
Very simple. The green wire is the bonding jumper instead of a metal strap. Remove it from the grounding screw on the frame and cap it or wrap it in electrical tape or cut the terminal end and run a wire nut on it. Now attach the green wire in the power cord under the frame grounding screw... your done. Kinda similar to the below diagram only your green bonding wire does not terminate at the terminal block .. instead it is terminated to the neutral elsewhere.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
titan (03-07-2011)
Old 03-07-2011, 05:18 PM   #3
Thank you. I figured this this what I needed to do bubt wanted to make sure.
I appreciate your help.
KC
Old 07-26-2011, 07:50 PM   #4
I have this same issue. Can I screw the new green (attached to the new 4 prong cord) to the external ground and leave the green ground wire that is already there screwed in underneath it?
sfranchu is offline   Reply With Quote
Old 07-26-2011, 08:11 PM   #5
Rewards Points: 6,652
No, you need to do what Stubbie stated in the reply to the OP.
Old 07-26-2011, 09:36 PM   #6
ok. I've got it all hooked up like Stubbie said to. Turned it on & it blows air, but does not heat. It looks like one of my "hot" wires is fried. Apparently this dryer that was advertised as "works great" wasn't in such great working condition. What can I do? Can I replace the fried wire?
Old 07-26-2011, 10:13 PM   #7
Are you sure that it is not something else. If you are getting 240 across L1 & L2, and 120 across L1 & Neutral, same for L2 & Neutral, then yes your machine may be bad, and you will have to contact where you bought it from.
Old 07-26-2011, 10:24 PM   #8
Yes, everything checks out voltage-wise. I bought it used off craigslist and am probably screwed that way.
So I have come to the conclusion that the problem is internal heating. Any ideas where to start?
Old 07-26-2011, 10:47 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Most electrique dryers AFAIK they will have a thermal fuse in the heating element area so if it was overheated before for some reason it will blow the thermal fuse so prevent from the heater kicking on after you verify the source is legit 120 / 240 volts.
The only way you can get into the thermal fuse with most of Américane dryers typically in the back so you will have to open up the top and maybe back and some case may have to remove the dryer drum depending on what brand name and where the thermal fuse is located.
However there is one serious warning make sure you unplug the dryer before you take anything apart there is few exposed termails points so be aware with it.
Merci,
Marc
Old 07-27-2011, 08:23 AM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,970
Replacing the heating element in a dryer is usually not hard. An appliance repair shop that services that brand can get you the part.
mpoulton is offline   Reply With Quote
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 02:35 PM
Dryer with no heat/House power issue Raygun Electrical 15 03-03-2010 11:26 AM
Gas Dryer - Electric Dryer gannys General DIY Discussions 8 10-13-2008 04:50 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 10:45 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
