3 Prong Cord Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 12:39 PM   #1
3 prong cord hook up
I am installing a new dishwasher and I have to hook up a 3 prong electrical cord. I bought a kit and the middle wire is clearly labeled "grounding wire". I need to hook up the 2 remaining wires to the dishwashers black and white wires. My question is does it matter which of the 2 remaining wires on the cord I attach to black or white? Neither is labeled black or white, positive or negative.
desperado is offline   Reply With Quote
Old 12-30-2010, 12:43 PM   #2
Rewards Points: 512
yes, it matters. connect black to black and white to white.
The Following User Says Thank You to sirsparksalot For This Useful Post:
desperado (12-30-2010)
Old 12-30-2010, 12:47 PM   #3
Ok...thats the problem..the only wire on the cord that is color coded is the green wire..the other 2 do not have colored interior coverings that I can see..they came pre stripped..the outer covering of the cord is standard gray with no pos or neg markings....
Old 12-30-2010, 12:50 PM   #4
wait, I think I found it...on the front of the plug itself there is a "w" next to one of the prongs..I'm assuming this is white..thanks!!!
Old 12-30-2010, 12:52 PM   #5
Rewards Points: 82
It does not matter.
Old 12-30-2010, 12:55 PM   #6
Licensed electrician
Rewards Points: 1,290
Look for a ridge on one side of the cord. This will be the white wire.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
desperado (12-30-2010), oh'mike (12-30-2010), Saturday Cowboy (12-30-2010)
Old 12-30-2010, 01:06 PM   #7
Ok..didn't see any white or black..I'm assuming, hopefully, that the "w" next to one of the prongs stands for white..there is a "g" next to the top prong for "ground" I'm assuming again..
Old 12-30-2010, 01:08 PM   #8
Yup..the ridge is on the same side as the "w" prong..thanks so much!! My wife would have been pissed if I blew up her new dishwasher - I would then replace that one by manually doing dishes!!
Old 12-30-2010, 06:08 PM   #9
joed's Avatar
Rewards Points: 12,022
It does matter. The black wire goes to the smaller of the two prongs. It's the left prong when looking at the plug. It might not be smaller on a three prong plug.
Old 12-30-2010, 08:01 PM   #10
Rewards Points: 1,452
Point the plug at the receptacle (outlet), that is, away from you, and with the ground pin at the bottom. The "white" or neutral prong is to the left.
3 prong to 4 prong dryer cord nwilson1987 Electrical 6 09-08-2010 01:11 AM
wire built-in dishwasher to hook to extension cord purpleheart Electrical 12 05-09-2010 11:07 AM
Help! Rewiring 3 prong to 4 prong cord rickysnaffi Electrical 7 07-07-2009 11:28 AM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 05:42 PM
3 Prong Range Hook up question tulsa442 Electrical 20 04-15-2008 10:58 PM
