3 Prong To 4 Prong Dryer Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 08:57 PM   #1
3 prong to 4 prong dryer cord
i have a 3 prong dryer that i need th change to 4 prong but the 4 prong is color coded dark green yellow red and light green and the 3 prong is not color coded so how do i hook it up?
nwilson1987 is offline   Reply With Quote
Old 09-07-2010, 09:13 PM   #2
Licensed electrician
Rewards Points: 1,876
Unless you have 4 conductors in your wiring method you cannot change the receptacle.
Old 09-07-2010, 09:31 PM   #3
The model dryer should outline how to connect the 4 prong cord
Mine has the wiring diagram on the back of the dryer
Or a manual should be available one line
Where are you located ?
Old 09-07-2010, 09:37 PM   #4
Unless the OP has 4 conductors the cord cannot be changed and just leave the one prong unwired.
Old 09-07-2010, 09:40 PM   #5
I don't see anywhere that he mentioned changing the receptacle
Old 09-07-2010, 09:47 PM   #6
Sorry, looks like I misread the Op.
Old 09-08-2010, 12:11 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Sound like non standard colour cord you have there.
Did you check with the manufacter instruction ??
Normally the North Americine connections are Black , Red both are line while White is netural and { Dark } Green is ground.
The only way you can do this in correct way is take a ohm meter and read it out the two vertical blades are hot while the round pin is ground and the L shaped blade is netural.
If you feel the colour is not correct just go back where you got the cord and get the correct one.
Merci.
Marc
Installing a 4 prong dryer plug Amandamayes Appliances 4 07-16-2010 01:17 PM
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 10:25 PM
Help! Rewiring 3 prong to 4 prong cord rickysnaffi Electrical 7 07-07-2009 10:28 AM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
