-   -   3 prong to 4 prong dryer cord (http://www.diychatroom.com/f18/3-prong-4-prong-dryer-cord-80798/)
nwilson1987 09-07-2010 09:57 PM
i have a 3 prong dryer that i need th change to 4 prong but the 4 prong is color coded dark green yellow red and light green and the 3 prong is not color coded so how do i hook it up?
Jim Port 09-07-2010 10:13 PM
Unless you have 4 conductors in your wiring method you cannot change the receptacle.
Scuba_Dave 09-07-2010 10:31 PM
The model dryer should outline how to connect the 4 prong cord
Mine has the wiring diagram on the back of the dryer
Or a manual should be available one line
Where are you located ?
Jim Port 09-07-2010 10:37 PM
Unless the OP has 4 conductors the cord cannot be changed and just leave the one prong unwired.
Scuba_Dave 09-07-2010 10:40 PM
I don't see anywhere that he mentioned changing the receptacle
Jim Port 09-07-2010 10:47 PM
Sorry, looks like I misread the Op.
frenchelectrican 09-08-2010 01:11 AM
Sound like non standard colour cord you have there.
Did you check with the manufacter instruction ??
Normally the North Americine connections are Black , Red both are line while White is netural and { Dark } Green is ground.
The only way you can do this in correct way is take a ohm meter and read it out the two vertical blades are hot while the round pin is ground and the L shaped blade is netural.
If you feel the colour is not correct just go back where you got the cord and get the correct one.
Merci.
Marc
