3-Prong To 4-Prong Conversion - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 07:02 AM   #1
3-Prong to 4-Prong conversion
I just move and had to converted my 3-prong plug to a 4 prong plug on my Frigidaire dryer to accomodate a 4 prong receptacle. Now the top, back right corner of the dryer gets very hot. What can the cause be? I wired the 4-prong plug as indicated below;
1 - green to frame
2 - black to left ternminal
3 - white to center terminal
4 - red to right terminal
5 - green ground strap removed from frame to center terminal with white wire
sanseve is offline   Reply With Quote
Old 05-23-2009, 07:56 AM   #2
Licensed Pro
Did you hookup the vent and is the vent line clean?
Old 05-23-2009, 08:33 AM   #3
Yes, dryer and vent are clean and properly connected. There are no obstruction to the outside discharge.
Old 05-23-2009, 08:37 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Well, you wired the cord right. How is the receptacle? Not that I think that has anything to do with it.
Old 05-23-2009, 12:42 PM   #5
Rewards Points: 58
From what I understand about dryers is that they are designed to get hot. Some spots more than others maybe? Call Frigidaire and ask them about your particular situation/problem. It is probably nothing to worry about.
Old 05-23-2009, 03:17 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
have you checked to see if the receptacle is hooked up properly. If the neutral and one of the hots is reversed, you could be running 240 volts to parts that are 120 volt rated.
check the voltage, on the recep, from each hot leg to neutral and from each hot leg to ground and both hot legs to each other.
4 prong to 3 prong 1meanek Electrical 11 05-03-2009 07:47 PM
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 05:42 PM
dryer Outlet change 3 prong to 4 prong oldpirate General DIY Discussions 2 08-06-2008 07:18 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 07:39 AM
