Old 11-19-2005, 11:22 PM   #1
3 prong 4 prong 240 ranges.
I've got some rentals and about half the ranges are 3 prong and the others are 4 prong. Are there any issues I should be concerned with on the 3 prong? Should I be looking at getting them changed over to 4 prong? Thanks for all the good advice. HS.
K2eoj is offline   Reply With Quote
Old 11-21-2005, 07:39 AM   #2
Electrical Contractor
As long as you are not renovating the kitchen then using the exsiting 3 wire is ok. The ony advantage would be if you swaped the ranges from house to house, then you might want to change them all to 4 wire so yoou would not have to change the plugs.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Tip for ranges with a non working control panel. Jeekinz Appliances 1 03-11-2008 03:20 PM
Replacements for two prong outlets? Tmb9862 Electrical 9 01-10-2007 10:11 AM
