-   -   3 prong 4 prong 240 ranges. (http://www.diychatroom.com/f18/3-prong-4-prong-240-ranges-1330/)
K2eoj 11-19-2005 10:22 PM
I've got some rentals and about half the ranges are 3 prong and the others are 4 prong. Are there any issues I should be concerned with on the 3 prong? Should I be looking at getting them changed over to 4 prong? Thanks for all the good advice. HS.
jbfan 11-21-2005 06:39 AM
As long as you are not renovating the kitchen then using the exsiting 3 wire is ok. The ony advantage would be if you swaped the ranges from house to house, then you might want to change them all to 4 wire so yoou would not have to change the plugs.
