3 Phase To Single Phase Conversion - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 09:45 PM   #1
3 Phase to single phase conversion
Greetings. I am a welder/fabricator and a regular on the Miller welding site. I am in need of some electrical advice.I currently purchased a hydraulic ironworker (metal cutting and forming equipment.) It has a 3 phase 7.5 hp 1750 rpm motor that runs a hydraulic pump for a 60 ton hydraulic cylinder.I do not have 3 phase power but I can get the same motor in single phase.So my question is can a single phase electric motor with the same specifications work without loss of hydraulic power or should I go bigger? if so is the capicator start capicator run the best motor for this application? or should I get a 3 phase converter? My concern with a phase converter is that I will loose up to 10% of power
fabricator is offline   Reply With Quote
Old 01-14-2011, 10:08 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
A single phase motor and 3 phase motor of the same size and rpms will produce the same results.
A single phase 7.5 hp motor pulls 46-47 amps, so you need to make sure your service will handle the extra load.
I looked at the table wrong last night.
The correct amps should be 40 amps@ 230 volts.
jbfan is online now   Reply With Quote
Old 01-14-2011, 10:29 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... Alota times it's cheaper to get a phase converter, 'n use it's original motor....
Old 01-14-2011, 10:29 PM   #4
Rewards Points: 154
get a vfd
awdblazer is offline   Reply With Quote
Old 01-14-2011, 11:23 PM   #5
MXer
3 legged dog's Avatar
Vfd's are nice. Cost around $1000. New motor, around $800.
3 legged dog is offline   Reply With Quote
Old 01-15-2011, 01:07 AM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,860
Here's a suitable VFD for $799:
http://www.driveswarehouse.com/Drive...FD/PC1-75.html
I would solve this problem with a VFD rather than replacing the motor or using a rotary phase converter. The VFD replaces the electromechanical motor starter/contactor that would otherwise be needed, and is very easy to interface with other controls. Variable speed can be really useful in many applications.
mpoulton is offline   Reply With Quote
Old 01-15-2011, 02:06 AM   #7
" Euro " electrician
frenchelectrican's Avatar
If you want to keep that 7.5 CV { HP } three phase motor then you will need the VSD unit at least 15 CV rated due the single phase input set up.
So be aware with this due most VSD on med to larger units they will derated it.
The other option you can use is rotary phase converter { this will be next best appaction for this useage due you have hydrallic pump the staic unit will not really handle the surge very well. }
As Jbfan mention how much current it will draw on single phase verison so expect that and make sure if you have subpanel in there make sure it is large engouh to handle the motor load.
Merci.
Marc
Old 01-15-2011, 03:34 AM   #8
This is certainly true if the VFD is intended for 3-phase input but being used with single phase. The VFD I linked to is specifically a single-phase input device, so it does not need to be derated.
Old 01-15-2011, 06:52 AM   #9
Thanks for your answers. I have plenty of 220/240 power. My shop is equiped with 400 amp service and all my 220/240 outlets are rated for 50 amps. Either way single or 3 phase I am still gonna replace the motor being it is 30 years old. I am doing a total rebuild on it including all new wiring, hydraulics, blades etc. So single phase conversion would be more cost efficient.
Old 01-16-2011, 11:24 AM   #10
Rewards Points: 58
Go to www.automationdirect.com or www.wegelectric.com. for VFD pricing.
Old 01-16-2011, 01:07 PM   #11
Rewards Points: 154
i think a vfd would be cheaper than changing to a single phase motor as a vfd will take a single phase input and output three phase
Old 01-16-2011, 07:08 PM   #12
A 7.5 hp single phase motor is cheaper than a VFD.Think I will put a 10 hp single phase motor on it, they run in the $800.00 range. I am rewiring the whole thing anyways.
Old 01-17-2011, 07:53 AM   #13
Rewards Points: 154
800 bones? you can get vfds cheaper
http://www.vfds.com/cart/index.php?m...ff8fda916abf96
for an example
Old 01-17-2011, 10:41 AM   #14
for an example
Why does the input and output on this say the same thing? I also feel that adding one of these converters will not hold up long being it has a lot more electronics to go out, not the ideal conditions in a un-climate controlled welding shop. I can get a new 10 hp single phase motor for $700.00 the existing 3 phase motor is 30 years old so I might as well replace it anyways.
Old 01-17-2011, 12:14 PM   #15
That VFD is intended for 3-phase input and output (most VFDs are). It is also 460V, not 208-240. It will not work for your application.
You can use a 3-phase input VFD with a single-phase source, but you need to over-size it by about 50%.
Converting 3 phase equipment to single phase /VFD? lightison Electrical 7 01-04-2011 04:14 PM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 10:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 11:49 AM
