3 Phase Service Panel And More - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 01-31-2013, 11:05 AM   #1
3 phase service panel and more
Hello,
I have to update an existing 3 phase in small commercial building and add 2 lines with 4 wire connection for a bun coffee machine
How to make it better?
Where to get neutral and ground
BUN machine needs 4 wire 208 service line
Please, see image with comments
Thanks beforehand for any recommendations
DoingMySelf is offline
Old 01-31-2013, 11:15 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
You need an electrician!
jbfan is online now
The Following User Says Thank You to jbfan For This Useful Post:
HouseHelper (01-31-2013)
Old 01-31-2013, 11:15 AM   #3
Rewards Points: 243
A coffee maker that requires 3 phase!!!??
chemman is offline
Old 01-31-2013, 11:34 AM   #4
Rewards Points: 1,532
Yes they manufacture coffee makers that are almost as big as water heaters.
If the 3 phase service does not already have a neutral then it might not be possible to connect up equipment that needs a neutral.
Generally you may not run 208 volt equipment on a 240 volt 3 phase system due to overvoltage considerations.
In many cities you need an electrician's license to work in commercial buildings or multi-family residential buildings. Small items such as replacing a broken receptacle are usually exempt from this requirement.
AllanJ is offline
Old 01-31-2013, 12:32 PM   #5
I can add/run that line myself but want to do it by code.
The upper -second panel not in use anymore.
The only question is about the neutral for the coffeemaker.
I is 2 phase 208 : one black, red, white, green.
there is a "smart" board inside of it and it is connected with transformer.
So, I am not sureif I can just run ground and short it with neutral.
Old 01-31-2013, 02:57 PM   #6
You may not run just the ground and short it with neutral.
Neutral must run separately out of the main panel or a subpanel to wherever it is going.
What is the voltage from hot to ground (each leg) at your main panel?
AllanJ is offline
Old 01-31-2013, 03:22 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Sorry. I do not help people working this far out of their area of expertise, trade, liability, insurance, etc.
If you have to ask how to wire a simple 3-phase Bunn machine you should NOT be doing this work.
HIRE AN ELECTRICIAN. This is NOT a job for a handyman.
Speedy Petey is offline
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (01-31-2013), mpoulton (01-31-2013)
Old 01-31-2013, 03:46 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
This thread, in my opinion, is dangerous to anyone who may try this. There are several professional electricians have commented and it seems they feel the same. Therefore I am locking the thread. Thank you.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now
The Following 3 Users Say Thank You to BigJim For This Useful Post:
frenchelectrican (01-31-2013), mpoulton (01-31-2013), oh'mike (02-01-2013)
Closed Thread
