-   -   3 phase service panel and more (http://www.diychatroom.com/f18/3-phase-service-panel-more-170649/)
DoingMySelf 01-31-2013 12:05 PM
1 Attachment(s)
Hello,
I have to update an existing 3 phase in small commercial building and add 2 lines with 4 wire connection for a bun coffee machine
How to make it better?
Where to get neutral and ground
BUN machine needs 4 wire 208 service line
Please, see image with comments
Thanks beforehand for any recommendations
:no:
jbfan 01-31-2013 12:15 PM
You need an electrician!
chemman 01-31-2013 12:15 PM
A coffee maker that requires 3 phase!!!??:eek:
AllanJ 01-31-2013 12:34 PM
Yes they manufacture coffee makers that are almost as big as water heaters.
If the 3 phase service does not already have a neutral then it might not be possible to connect up equipment that needs a neutral.
Generally you may not run 208 volt equipment on a 240 volt 3 phase system due to overvoltage considerations.
In many cities you need an electrician's license to work in commercial buildings or multi-family residential buildings. Small items such as replacing a broken receptacle are usually exempt from this requirement.
DoingMySelf 01-31-2013 01:32 PM
:huh:I can add/run that line myself but want to do it by code.
The upper -second panel not in use anymore.
The only question is about the neutral for the coffeemaker.
I is 2 phase 208 : one black, red, white, green.
there is a "smart" board inside of it and it is connected with transformer.
So, I am not sureif I can just run ground and short it with neutral.
AllanJ 01-31-2013 03:57 PM
You may not run just the ground and short it with neutral.
Neutral must run separately out of the main panel or a subpanel to wherever it is going.
What is the voltage from hot to ground (each leg) at your main panel?
Speedy Petey 01-31-2013 04:22 PM
Sorry. I do not help people working this far out of their area of expertise, trade, liability, insurance, etc.
If you have to ask how to wire a simple 3-phase Bunn machine you should NOT be doing this work.
HIRE AN ELECTRICIAN. This is NOT a job for a handyman.
BigJim 01-31-2013 04:46 PM
This thread, in my opinion, is dangerous to anyone who may try this. There are several professional electricians have commented and it seems they feel the same. Therefore I am locking the thread. Thank you.
