3-phase Residential/Commercial - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 06:50 PM   #1
Hello There...I'v got a mobile home w/ a 100amp Service Panel and am building a small printing shop next door. I have two extra spaces from the Main Panel to feed a 70Amp Subpanel to the shop, easily for lighting and recepts. However I have one printer that requires a 3-phase 30Amp Breaker. Right now that printer is hooked up to a Square-D 3-phase breaker, but in a Commercial Building. Would I need to purchase a different kind of Panel w its own Commercial Service or can I snap that 3-pole or 3-phase Circuit Breaker into a Residential Subpanel? Appreciate any help!
jammbud is offline   Reply With Quote
Old 01-22-2008, 06:59 PM   #2
It's not gonna happen. You will not have 3 phase available at your trailer.
3 phase is provided from the power company. 3 hots, one neutral.
You will have single phase at the trailer. 2 hots, 1 neutral.
Get new equipment or google "phase converter". About 300 bucks.
220/221 is offline   Reply With Quote
Old 01-22-2008, 07:04 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
So you're going to feed a "commercial" space with 70a from a 100a residential service??? Doesn't sound like the best idea to me.
Old 01-22-2008, 08:27 PM   #4
Oh no kidding ...yeah the 20'x20ft' room or building will be like a standard 1room circuit for the lighting and about 8 outlets but the 3-phase printer is whats throwing it off. Yeah I guess the single phase wont handle that so I guess the Converter is the only way to go then huh if thats the printer I want to keep? And also would I need a bigger Subpanel than 70Amp if I use the 30Amp 3-phase Converter?
Old 01-22-2008, 09:14 PM   #5
Bigger is always better but....I don't know. I don't think the draw on the converter is much more than the machine itself.
Google for the specs.....or buy/trade a single phase printer.
It's called bootstrapping. Some very sucessful enterprises have started in a garage or behind a trailer.
Old 01-22-2008, 09:26 PM   #6
Thanks 220/221..can I run a 100Amp Subpanel off the 100 Amp Main?
Old 01-22-2008, 11:27 PM   #7
Res Ipsa Loquitur
No- not according to Stubbie from another post:
"One last thing...if your dwelling service panel is 100 amps you cannot subfeed out of it with an installed 100 breaker to another panel of equal amperage or greater. A 100 amp panel will only have a bus stab rating of 70 amps in the Usa this will be the largest breaker you can sub-feed with. All panels have bus stab ratings depending on the rating of the panel. The exception being panels that have feed thru lugs"
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 01-22-2008, 11:53 PM   #8
So I guess Im wondering now if I purchase the 3-Phase Converter, will it work in a 100Amp Subpanel that will be feeding off the 100Amp Main Panel without tripping? The 3-Phase should be converted down to the Double Pole 30Amp Breaker right? And the remaining circuits for the standard residential room lighting and outlets will be 20Amp.
Or am I better off just gettin a whole new 200Amp Main to the trailer then feeding the 100Amp Sub off that?
Again, at this moment at a different location in Az., the 3-Phase Printing machine is running off a 3-Pole 30Amp Breaker, in a commercial building, using 10-3 Romex. But I need to move my printer to my house into this small room next to the trailer.
One more thing I didnt mention is my trailer has a 100Amp Disconnect or meter from utility pole then goes inside the trailer to the 100A Panel. Thanks so much for your help!
Old 01-22-2008, 11:57 PM   #9
Thanks handyman78 didnt see you but that answers that question about feeding a 100Amp Sub from a !00Amp Main. Damn here I was trying to save some bucks..haha. I guess Ill have to get a 200Amp Main Panel unless my 3phase will run off a 70Amp Sub.
Old 01-23-2008, 12:05 AM   #10
The Panel inside the trailer is a main lug 100A panel and the disconnect or meter at the pole has the !00Amp Breaker.
Old 01-23-2008, 06:37 AM   #11
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,.......
You need a new Bigger service entrance to do what you're attemping to do......
Maybe a Bigger "100Amp Disconnect or meter from utility pole",...
Then branch off to the trailer,+ to the Shop......
Old 01-23-2008, 06:56 AM   #12
I run a 7.5 hp rotary phase converter off my 60a subpanel, from my 100a main. The phase converter requires a 30A 2-pole breaker. I run a 5hp jointer and 1.5 hp lathe off the converter.
I think you'll be fine.
NateHanson is offline   Reply With Quote
Old 01-23-2008, 07:48 PM   #13
Is there an extra 2 pole space in your meter pedestal? You might want to run it from there. I have installed a few AC circuits in trailers this way.
I'd come and look at it for you but I swore off trailers Nothin but trouble.
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
changing single phase to 3 phase bentaypink Electrical 10 12-15-2007 04:23 PM
3 phase crazydog Electrical 10 08-20-2007 11:47 PM
3 phase electricity J187 Electrical 11 10-26-2006 02:40 PM
