3 Phase Problem...help - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 05:43 PM   #1
Question
3 phase problem...help
Hi we are opening a very small hotel in Andalucia, Spain and were told that 3 phase would be installed in the village by November but Spain being Spain it could be a couple of years late!! not good for us as we need it to run the pool, air con etc etc. The following has been suggested but I don't have anyone to ask if it is actually possible...The new hotel is set up for 3 phase the line coming in at the moment is mono. We have been told that we may be able to connect directly to the village transformer but
The next prob is that the current 3 phase supply at the transformer is 220 v as opposed to the modern 380v. he says that a machine is available - he's trying to discover how much - which upgrades current from 220 to 380 v.
Is there such a machine available? anyone got any idea on price.
Hoping someone can advise
thanks
Julianna is offline   Reply With Quote
Old 10-21-2008, 05:50 PM   #2
joed's Avatar
Rewards Points: 12,862
He is probably refering to an M-G set. That would be a motor generator. A mono phase motor turns a three phase generator to generate what ever power requirements you have. You would need to get a quote from someone local for a price.
Old 10-21-2008, 10:13 PM   #3
thanks
How much trouble would it be to replace the motors with 200/3ph motors.
Perhaps used motors could be purchased, then when the up-dated power is available, the new motors could be put back!
Motor-Gen sets are an expensive proposition!
Old 10-22-2008, 10:19 AM   #4
Rewards Points: 160
If you cannot count on the upgrade from the utility, you should just use what you have. 3 phase 220. Most motors are dual voltage anyway. 220/380. Then all you would have to do when they do the upgrade is change the motor connections. Use the same motors.
Take a look at a few of the motors and see if they are indeed dual voltage, if they are the answer is simple.
Old 10-22-2008, 02:07 PM   #5
joed's Avatar
Actually after rereading your post I realize you are talking about going from 3 phase 220 to three phase 380. That would be a transformer not an M-G set. Much cheaper and simpler to do. I was thinking about going from single phase to three phase. That is where an M-G would be good.
Old 10-22-2008, 06:11 PM   #6
" Euro " electrician
frenchelectrican's Avatar
The simple soluation with older 230 volt 3 system is use delta/wye transformer to upstep the voltage and it is very common methold to change voltage on the system.
You will have to get a hold of your electrician in your area so they can able hook up right and also know the correct transfomer size as well.
Merci,Marc
Old 10-23-2008, 11:24 AM   #7
Rewards Points: 160
Merci,Marc
Marc, is the 380 required? The OP stated she already has 3 phase 220.
Old 10-23-2008, 08:13 PM   #8
J.V. Yeah I am aware with the old 220Y127 system they are getting phasing them out due most of the european system now use 230V L-N 400~415 L-L.
It the same idea in France we have handfull of 220Y127 system left and once they upgraded the 220Y127 is no longer used.
Merci.
Marc
Old 10-24-2008, 10:57 AM   #9
Rewards Points: 160
Merci.
Marc
Thanks Marc
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
