3 Phase Power Phase Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 01:07 PM   #1
3 phase power phase question
I am installing a camera system that uses the wiring as the cable to transmit on. In a business setting it will only work on 1 of the 3 phases. Inother words it will NOT work across phases. My question is, without trial and error, connecting and trying each camera. IS there a device and I can plug in each recept to see if it's on the same phase as the other reecpticle ?
jelliott is offline   Reply With Quote
Old 12-18-2008, 04:28 PM   #2
Rewards Points: 862
Try re-posting in the Electrical forum.
Ultrarunner2017 is offline   Reply With Quote
Old 12-18-2008, 05:09 PM   #3
Measuring from the hot terminal of one receptacle to the hot terminal of another with a DVM, you will read less than ~3 vac if they are on the same Φ.
Old 12-18-2008, 05:20 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
That would be alot cheaper than a circuit tracer.
wirenut1110 is offline   Reply With Quote
Old 12-18-2008, 08:56 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I would imagine your talking about 208Y120 3 phase. Phase to phase is 208 volts. Any of the 3 phases to neutral is 120 volts. It won't matter what receptacle you plug into as they are all phase to neutral if you are talking about 120 volt wall receptacles like you have in your home.
Old 12-18-2008, 09:34 PM   #6
Rewards Points: 2,350
You could also just turn the breakers off to see what recept is on which phase. Every 3 breakers vertically will repeat phases. So, if the first breaker is A, the second B and the 3rd C, then the 4th will be A. It goes ABCABCABC etc.
Old 12-18-2008, 09:42 PM   #7
His problem is that the video signal will not travel through the transformer secondary windings.
For this reason, only receptacles wired to the same phase can be used.
Old 12-18-2008, 09:52 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Yes of course I see what your saying...thanks.... I thought he was saying he couldn't connect across phases. He needs to be on the same phase conductor ...gotcha.
Old 12-18-2008, 10:01 PM   #9
Rewards Points: 1,452
A very long (say 50 foot) single conductor with a regular power plug at the end, the wire is connected to the smaller prong (not the neutral). A short (say 2 foot) conductor connected to a regular power plug, smaller prong. A small board with two ordinary (porcelain?) lamp sockets connected to each other with one jumper wire, each with the same kind of small incandescent lamp. Connect the single conductors to the free terminals of the lamp sockets.
You now have a test instrument for what you want to do. If the lamps come on when the ends are plugged into different receptacles then the receptacles are on different phases. You needed two lamps (in series) to handle the 208 or 240* volts phase to phase.
* The same dilemma exists with single phase 120/240 volt systems; the video or radio frequency equipment all has to be plugged into the same "side of the line".
Old 12-19-2008, 10:29 AM   #10
Rewards Points: 862
You should also be able to purchase a "bridge" which would allow the carrier signal from the camera to travel across phases.
These devices are installed in the service panel, using 15A breakers.
You would need one specifically designed for a 3-phase system to allow the signal to travel across all phases.
Old 12-19-2008, 10:56 AM   #11
Which is probably a high pass filter.
Old 12-19-2008, 11:02 AM   #12
I wonder, just as a theoretical question, if placing three equally sized lamps on all the phases with a wye connected floating neutral would pass the signal? In other words, if you had three lamps sockets, and wired all three silver terminals together, but not to a neutral from the panel, and wired the three brass terminals to each phase, the lamps would burn with equal brightness. Would the signal cross these loads?
Old 12-19-2008, 11:32 AM   #13
The hot resistance of a 120v, 100w bulb is about 140Ω. If the signal source impedance is 75Ω, your destination signal would be reduced to ~ half the normal voltage and ~1/4th the normal power. There'd also be reflections because the Characteristic Impedance of the circuit (75Ω) is not maintained.
It might work, anyway.
Old 12-19-2008, 01:45 PM   #14
A LC filter would be simpler! Just a coil and capacitor in series. Perhaps 3 filters, phase to phase would do!
Thirty years ago, I used to play with this sort of thing. But, now i've forgotten.There are formula's to apply, and I would think that any electrical tech. worth his salt would come up with the answer in a minute!
See this site http://en.wikipedia.org/wiki/LC_circuit
Old 12-20-2008, 01:49 PM   #15
Rewards Points: 506
Send a message via AIM to theatretch85
Search for "Phase Coupling", its done a lot with X10 systems in houses where there are multiple interfaces through out a house.
http://kbase.x10.com/wiki/Phase_Coupling
If you have an electric dryer outlet, this would be an easy install (also available in the 4pin variety as well)
http://www.smarthome.com/4826B/Signa...epeater/p.aspx
Though you would probably need two to couple between all three phases.
theatretch85 is offline   Reply With Quote
3 phase power from 5 wire to 4 wire andrewmarcos@yahoo.co.uk Electrical 6 11-25-2008 11:07 AM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 04:23 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
No power Question fburke Electrical 4 06-11-2008 04:56 PM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
