Old 09-19-2012, 06:56 PM   #1
3 phase power help
In my barn I have a type of 3 phase that I am not familiar with and I am trying to find more info. It is a 60a service and when I go from hot to ground I get 645v from one, 363 from the next and 285 from the last one. From hot to hot I always get around 500v. I am planning on gettigg a transformer to make the power more usable but I would like to know more about what exactly it is. I have been collecting machining and welding equipment and I would like to know a little more before I start plugging stuff in. I am used to standard 277/480 power. Thanks for any help you can give me.
chadcooper55 is offline   Reply With Quote
Old 09-19-2012, 07:05 PM   #2
3 phase power help
#1 Go back and add your location to your profile. Sure sounds like your not in the US where most of us here from.
First things your going to hear is call an electrition when it comes to working with 3 ph.
Old 09-19-2012, 07:06 PM   #3
3 phase power help
I am in Michigan. I have spoke with multiple electritians and they all give me different answers.
Old 09-19-2012, 07:54 PM   #4
Electrical Contractor
3 phase power help
Troubleshooting over the internet with 3 phase and those crazy voltages will get you hurt.
You don't need to talk to one, you need one to come out and check themselves.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (09-19-2012)
Old 09-19-2012, 08:14 PM   #5
3 phase power help
I deal with high voltage a lot. I am not a complete newbie. I have encountered this power before. It is an old style 3 phase. I just don't know any more info.
Old 09-19-2012, 08:23 PM   #6
3 phase power help
suggest you call the electrical supplier for specifications and application procedures..they may be very helpful
techpappy is offline   Reply With Quote
Old 09-19-2012, 09:21 PM   #7
3 phase power help
Could be a high leg delta supply !
Or you are really across two phases,
rather then across neutral and one hot !
Ask your poco to check it out for you !
Be really carefull,
I dont have to tell you,
that voltages like that,
will destroy anything imediately.
Including you !
dmxtothemax is offline   Reply With Quote
Old 09-19-2012, 09:36 PM   #8
Msradell's Avatar
3 phase power help
+1 They will certainly be your best source of information!
Msradell is offline   Reply With Quote
Old 09-19-2012, 09:38 PM   #9
Semi-Pro Electro-Geek
3 phase power help
I suspect this is an ungrounded 480V delta service that is running a bit high of a voltage. 500V on a 480V service is only 4% above nominal, so while it is uncommon, it isn't necessarily a big problem. The unpredictable voltages between each phase and ground suggest that this service is not ground-referenced. In other words, it's ungrounded. That is uncommon, and is only appropriate in specific types of industrial installations where there is monitoring equipment in place to detect ground faults. You should not have an ungrounded service in a typical barn or shop - they are only for industrial plants with proper monitoring. If the service drop has ONLY three conductors, and all three are insulated, then you probably have an ungrounded delta service. The definitive test for this is to apply a load (like a string of 5 100W light bulbs) between each phase and a good actual ground (like a rod), while measuring the voltage. If it drops much at all, then the service is ungrounded. This test is a bit dangerous because the reference ground rod will be electrified during the test.
It is also possible that the service was originally grounded, but the grounding connection has failed over time. This could create a very dangerous condition, electrifying metal parts on the failed grounding system. If there is evidence of a neutral conductor anywhere in the system, then it was probably grounded originally. It may have been center-grounded like a normal 3-phase service, so the phase-to-ground voltage should be 277V. Or it may have been corner grounded, where one phase was bonded to ground and the other two are 480V with respect to ground. That is a common configuration for agricultural installations like irrigation well pumps. If your service drop has four conductors, or three insulated conductors plus a bare one, then you almost certainly have a 277/480V service with a bad ground. If the service drop has only two insulated conductors and one bare, then it was definitely a corner-grounded delta service that now has a bad ground. In either case, watch out! Metal equipment may be electrified.
Pictures of the panel and the service entrance would be very helpful.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
andrew79 (09-19-2012)
Old 09-19-2012, 10:01 PM   #10
3 phase power help
deleted
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 09-19-2012, 10:24 PM   #11
Missouri Bound's Avatar
3 phase power help
Contact the power company. From what you are saying you are in over your head.
Do you want it your way or the right way?
Single Phase Panel from Three phase 3 Wire Delta bsps Electrical 9 06-02-2012 09:44 PM
hELP! Amperage needed for 220V motors 1488rob Electrical 22 03-18-2011 04:28 PM
power to "half" the house dogvila Electrical 8 07-13-2010 10:04 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 04:19 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 11:49 AM
