3 Phase Power From 5 Wire To 4 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 05:41 AM   #1
3 phase power from 5 wire to 4 wire
i recently purchased a commercial dishwasher that requires three phase power. I have a 4 pin point near the machine 3ph and earth (no neutral). The machine has five wires hanging out of it, 3ph, neatral and earth. how do i wire this up without the neutral?
andrewmarcos@yahoo.co.uk is offline   Reply With Quote
Old 11-24-2008, 06:27 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
I would imagine you do not.
In the US you would have to run a new circuit; or in the extremely rare case of a full conduit run, pull a neutral in.
Old 11-24-2008, 08:34 AM   #3
DIYer
Are you sure it's 3ph and not 1ph 220 with neutral and ground (also 4 pins?)
Gigs is offline   Reply With Quote
Old 11-24-2008, 07:53 PM   #4
Single phase may be required for solenoids, timers etc!
If so, you'll require a neutral. No easy way out of it!
Old 11-24-2008, 09:36 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
OP stated machine has 5 wires. That would mean 3 phase plus neutral plus ground.
Old 11-25-2008, 12:37 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Normally in the UK system the voltage are 230 L-N and 400~415v L-L { both single and three phase }
You should double check the nameplate to see what voltage it required and It will be wise go get the electrician come in and have it termated proeprly due the L-L voltage may knock ya out.
Merci,Marc
Old 11-25-2008, 11:07 AM   #7
DIYer
I meant the outlet, not the machine.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
120/208/1 phase wiring questions JohnJon Electrical 11 09-01-2008 12:28 AM
Bring power to Ceiling Fan HELP mechcross Electrical 1 08-24-2008 06:45 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
I really need help! POOK Electrical 34 04-20-2007 08:01 PM
