Old 12-10-2009, 11:09 AM   #1
3 Phase meter socket question
I have a question about 3 phase metering:
I have a low voltage 3 wire 3 phase heater which is being metered through a single phase meter socket (I had the single phase meter lying around, and needed to separate the heater from the rest of the system to accurately measure it's usage). My question is this: Will the kw hours of usage be accurate when read through the single phase meter as opposed to an actual 3 phase meter socket? Any help with this question would be greatly appreciated.
Thanks.
a320200 is offline   Reply With Quote
Old 12-10-2009, 11:19 AM   #2
nap
You talking to me?
nap's Avatar
well, since a single phase meter cannot read the third leg, it cannot accurately record power flow.
Old 12-10-2009, 09:03 PM   #3
Idiot Emeritus
nap is right.
Even if it's a grounded B system, a special meter is needed.
Rob
micromind is offline   Reply With Quote
Old 12-10-2009, 10:30 PM   #4
Electrical Contractor
kbsparky's Avatar
Most single phase meters are single stator. You need a 3 stator meter to properly measure 3 phase power consumption.
-KB
Old 12-11-2009, 01:45 AM   #5
the meter will not be accurate. though since the heater is a resisitive load the phases will be balanced. you could probably multiply by 1.33 and get close.
smeric28 is offline   Reply With Quote
Federal Pacific Panel Replacement Question DIYDesign Electrical 5 03-16-2009 12:23 AM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
