3 Phase Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 09:16 PM   #1
3 phase disconnect
I have a main disconnect that serves 2 panels. The disconnect carries to pull out fuse blocks of three 200 amp fuses apiece for each leg. I was wondering if there was something on the market that would allow me to change out the two blocks of fuses for breakers because I tired of buying these fuses at $40 apiece.
Ryno133 is offline   Reply With Quote
Old 06-01-2010, 09:30 PM   #2
Electrical Contractor
kbsparky's Avatar
You need an I-Line distribution panel.
-KB
Old 06-01-2010, 09:30 PM   #3
Master Electrician
Rewards Points: 3,920
The first issue to address is why you are having to replace the fuses at all.
brric is online now   Reply With Quote
Old 06-01-2010, 09:56 PM   #4
" Euro " electrician
frenchelectrican's Avatar
The key issue is you have to check out the system and find out why you are blowing the fuses in first place .
Overload or what ??
If overload you have to figure it out how to reduce the load on that affected circuit.
If no overload then you may have loose fuseholder when it get hot it will trip or blow early.
Merci,Marc
Old 06-02-2010, 11:53 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
The second issue is WHY are you working on a 3-phase system?
A 200A fuse should NOT be $40 either.
Old 06-02-2010, 04:54 PM   #6
Master Electrician
i seriously doubt that if their worried about $40 dollar fuses(seems high) they want to spend the money on an I-line but that's definately the way to go.
As has been said many times already
A. do not work on 3 phase like it's a DIY project(especially at large amperages).
B. the fuses are blowing for a reason....find out what it is
hopefully if enough people say it it'll become reality
andrew79 is offline   Reply With Quote
Old 06-02-2010, 06:06 PM   #7
Union Electrician
goose134's Avatar
Wow, everything I was going to say has been said.
goose134 is offline   Reply With Quote
1 phase to 3 phase diesel boy Electrical 12 05-05-2010 11:57 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
