3 Phase - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2010, 02:31 PM   #1
3 phase
How do I ohm a three phase motor to know if It is good or not. The motor is on a garbage disposal. Insinkorator SS-150, do I just ohm the Three primary leads 1,2,3, . And is there a helpful website that explains three phase motors and wiring? Thanks in advance
Livewire78 is offline   Reply With Quote
Old 07-01-2010, 05:10 PM   #2
I=E/R
a7ecorsair's Avatar
Wow, a three phase garbage grinder.
http://www.insinkerator.com/product/...=32&template=c
This is in a commercial site?
A to B, A to C, and B to C should all read the same.
a7ecorsair is offline   Reply With Quote
Old 07-01-2010, 09:22 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I have see few but useally found in restuarnts or large area they are useally 3/4 HP or larger.
However just be forewarn some three phase garbage dispoal will have more than just 3 wires { it will be either 6 or 9 leads as well }
What voltage this motor is wired on 208 or 240 or 480 volts ?
If latter you will not able use it. unless you have transfomer to change the voltage.
Merci.Marc
Old 07-02-2010, 12:47 AM   #4
Rewards Points: 1,192
Measure the leads line to line ,looking for 20 ohms, then line to frame ,looking for open.
bobelectric is offline   Reply With Quote
1 phase to 3 phase diesel boy Electrical 12 05-05-2010 12:57 PM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 11:49 AM
120/208/1 phase wiring questions JohnJon Electrical 11 09-01-2008 12:28 AM
