3 Phase 240v? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 08:23 AM   #1
3 phase 240v?
Hi guys.
I'm looking at buying a sewing machine that has a red plug on it but the motor says 240V can I use this machine at home? It's on an auction site so can't try anything.
Thanks. Paul
toxo is offline   Reply With Quote
Old 04-24-2013, 08:26 AM   #2
joed's Avatar
Rewards Points: 11,986
There is no such thing as 3 phase 240. It is three phase 208.
Does the motor actually say three phase? 240 volts single phase is available in 99% of the homes in north America. You will have to install a proper receptacle to use it. It will plug into your normal three prong wall receptacle.
Old 04-24-2013, 08:30 AM   #3
Rewards Points: 13,260
Joed, did you mean to say it will not plug into a reguler outlet?
May want to edit what you said.
Old 04-24-2013, 08:56 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
3-phase 240 volt is a high leg delta system where phase to phase is 240 volts, 2 phases to ground are 120 volts, and 1 phase (high leg) is 208 volts to ground.
Pretty common in older services, not much used anymore in new services.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
mpoulton (04-24-2013)
Old 04-24-2013, 09:12 AM   #5
Idiot Emeritus
Rewards Points: 1,492
There are entire subdivisions around here that have 240 volt 3 ∆ services. The 3 is used for the A/C unit.
There also exists a 240 volt 3 system with only 3 wires, one of them is grounded, there is 240 from any wire to any other wire, but no 120. Mostly found on irrigation pumps, not buildings.
There are plenty of 240 volt single phase motors as well as 3. If possible, get a pic of the nameplate.
Rob
micromind is offline   Reply With Quote
The Following 2 Users Say Thank You to micromind For This Useful Post:
ddawg16 (04-24-2013), mpoulton (04-24-2013)
Old 04-24-2013, 09:19 AM   #6
Sorry guys. Didn't realise my location wasn't there. Over here we use 240V mains. The machine I'm after has a motor which states 240v but the plug that goes in the socket is a red safety plug which is normally used for a 3 phase supply. Question is.. can I use it on a single phase home circuit?
Old 04-24-2013, 09:27 AM   #7
Rewards Points: 1,440
If the motor itself has just two wires going into it and is labeled 240 volts, then you can connect it to a 240 volt single phase source.
The Following User Says Thank You to AllanJ For This Useful Post:
micromind (04-24-2013)
Old 04-24-2013, 03:54 PM   #8
joed's Avatar
If it is really a 3 phase unit then you can NOT use on a single phase system as it is.
There are converters available to convert the single phase to three phase or you could change the motor to a single phase motor.
The Following User Says Thank You to joed For This Useful Post:
Old 04-24-2013, 04:11 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Did anyone notice that the OP is in England? Local power is 240Vac 50Hz.
If the plug looks like this...good to go...
ddawg16 is online now   Reply With Quote
Old 04-24-2013, 04:56 PM   #10
Philly Master's Avatar
Rewards Points: 516
well since Philly is what is old when speaking of electric ...LOL
we have 208 3 phase in the city .. usually high leg b phase
out in the suburbs you see more 240 3 phase all legs 120 to ground
and we still have some 2 phase 5 wire ....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-24-2013, 05:48 PM   #11
I suppose the question can't be answered without more info. I was merely trying to ascertain whether the thing (labeled 240V) could be wired to use at home. It does have a RED 3 phase plug on it but I don't know if it's been put on there as some kind of safety feature. Wishful thinking I think.
Old 04-24-2013, 06:47 PM   #12
Idiot Emeritus
Correct.
You'll need to know if the motor is single phase or 3 phase.
Old 04-24-2013, 07:07 PM   #13
dmxtothemax's Avatar
Rewards Points: 5,100
Can you post a pic of the plug and cord ?
If not, look on the plug for a model number and brand ?
What type of plug is it ?
How many pins ?
What shape are they ?
What pattern are they ?
dmxtothemax is offline   Reply With Quote
Old 04-24-2013, 07:46 PM   #14
out in the suburbs you see more 240 3 phase all legs 120 to ground:
Psst! The high leg 3 phase is the 240 volt kind (delta system).
The symmetric (wye, all legs 120 to ground) is the 208 volt kind.
Older primary (substation to street) lines may be 4KV (4160 volt) phase to phase or 2400 volts
phase to ground.
In cities, modern primary lines are typically in the 13000 volt phase to phase range, in rural areas they
could run up to 30000 volt phase to phase usually with just one of the three phases serving
each street.
Depending on the pole transformer array, buildings receiving 3 phase power might get either
120/208 or 120/240 volt (secondary) power regardless of the primary voltage.
Philly Master (04-25-2013)
Old 04-24-2013, 08:33 PM   #15
An old Tradesmen
Rewards Points: 6,470
Originally Posted by AllanJ View Post
Psst! The high leg 3 phase is the 240 volt kind (delta system)..
That will ay with the area. My town, 240 volt is high legged. A city not far a way, 230 volt is high legged.
240v Out of Phase Due to Fuses? CloudNine Electrical 9 10-11-2012 04:32 PM
irrigation pump shutdownMy Sta-rite 2 HP centrifugal self priming single phase 240V i Oly Electrical 7 06-17-2010 11:44 AM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 04:46 PM
208V vs 240V 3 phase pcampbell Electrical 14 07-28-2009 12:12 PM
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-24-2009 12:06 AM
