3 Outlets not working
you say there are no GFI's in the house. if you're certain about this, then thats not the problem.
you also stated one breaker goes to half the house, and one breaker goes to the other half.
Are we then to assume half the outlets and lights are on one circuit, and the other half are also on one circuit?? (two circuits for most of the house)
if this is true, you need to find where the power stops feeding these "dead" outlets.
Are the three dead outlets all on the same circuit?? and if so, does anything else on this circuit work??
Knowledge is Power, but 240v can Keel You!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
