3 Out Of 4 Items In Circuit Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 10:19 AM   #1
3 out of 4 items in circuit not working
last night we lost power in 3 of electrical outlet in a room a light on the same circuit however still works. it appears as if there is power running to the hot lead but not to the neutral lead however this would not explain why the fourth (a light socket last item on the circuit )still works. I am assuming a loose wire or shorted out wire however unable to locate a source for this problem.
any suggestions or should we just call an electrician
brianes99 is offline   Reply With Quote
Old 01-22-2011, 10:58 AM   #2
Rewards Points: 1,192
As an electrician... Call an Electrician. Otherwise turn circuit off,and replace all receptacles that aren't working.
bobelectric is offline   Reply With Quote
Old 01-22-2011, 11:03 AM   #3
thanks. we started with replacing 2 of the outlets.
Old 01-22-2011, 11:10 AM   #4
joed's Avatar
Rewards Points: 5,468
The problem is a loose neutral. It could be in one of the dead devices or in a working device. Open everything and look for a disconnected white wire.
If you know how the cable are routed then the problem is in the last working or the first not working device.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-22-2011, 11:26 AM   #5
ok. replaced first in line. last in line is working light but will check it
Old 01-22-2011, 12:00 PM   #6
Retired from the grind
gregzoll's Avatar
Rewards Points: 3,336
If you had a short, your breaker would trip every time you tried to reset it. What you have, is a open. This is why AFCI breakers were designed.
Old 01-22-2011, 12:03 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Knowing what is first in line is not always obvious and knowing how the cables actually are routed isn't either. If what you think is the last receptacle in the same circuit is working that eliminates any wiring problem like an open neutral in the circuit. Unless pigtails to the receptacles that are not working have bad connections.
Are your receptacles back stabbed...meaning do the wires poke into holes in the back of the receptacle?
Are you sure that the receptacle that is working is not in fact the first receptacle before the receptacles that are not working ?
Also if you would as you open these receptacle boxes could you tell us how many cables are entering those boxes. Your receptacle that is at the end or last in line should only have one cable entering the box with 2 wires and a ground but if no ground wire then just two wires (black and white).
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-22-2011, 01:02 PM   #8
only one recepticle is wired to be source for another outlet further down
Old 01-23-2011, 04:25 AM   #9
Scared Electrician
Saturday Cowboy's Avatar
then we have more than one circuit or a jbox somewhere!
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-23-2011, 04:36 AM   #10
oh yes! definately more than one junction. and of course the box that splits the lines for this room appears to be behind a wall. replaced circuit breaker and all outlets in room.
So either its the junction I can't get too or a one of two long stretches of wire that feeds the room.
i'll explore those options today
Old 01-23-2011, 04:48 AM   #11
Scared Electrician
Just a heads up all electrical must be accessible.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
Rewiring furnace electrical circuit BlueBSH HVAC 4 09-21-2010 01:34 PM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 12:41 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
