3 In One Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 06:37 PM   #1
3 in one switch
i have a 3 gang box that control 3 different lights with 3 different switches. i want to use a single gang box with a switch i bought that controls the 3 lights with separate buttons on 1 switch. not sure how to wire it there is 2 hots 3 neutrals and a ground? it is a pass&seymour tm8111
kicken asphalt is offline   Reply With Quote
Old 03-07-2011, 06:41 PM   #2
Licensed electrician
Rewards Points: 1,888
You should not have neutrals connected to a switch. Describe the number and colors of wires attached to each switch.
I suspect you have switch loops involved and you might not be able to make the change.
Old 03-07-2011, 06:51 PM   #3
i'm sorry jim the new switch has a black screw and a gold screw on 1 side 1 black and 2 golds on the other and a green screw on the bottem
Old 03-07-2011, 06:55 PM   #4
Electrician Canadian Eh!!
I believe this info will help.
http://tools.passandseymour.com/pdf/...11_E20-E21.pdf
It looks like the switch(es) can share a common feed or be fed from 2 seperate circuits(The middle screws on both sides). The switch wires are connected on the other 3 screws. And of course there is the ground screw on the end.
Hope this helps!!.
hhuggles is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
