3 KVa / Formula - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 07:22 PM   #1
3 KVa / formula
Doe's anyone know how to plan a 3 kva, line side fuse size?
Gotta Go will be back tomorrow to see results.
Thanks Carandorandy.
Carandorandy is offline   Reply With Quote
Old 02-24-2011, 08:27 PM   #2
Electrician
Rewards Points: 788
yes you figure out the amps, determine if it is a continous or non continous load and then determine from that what size fuse you need.
Your question is way to vague for anyone to give you the proper answer.
darren is offline   Reply With Quote
Old 02-25-2011, 09:49 AM   #3
Calculating Overcurrent Protection on the Primary Side
3 KVA dry type transformer (Calculating Overcurrent Protection on the Primary Side)?
I will run #12 THHN wire as we usualy do but the current on the load is some constant at about 1.5 amps for a low voltage power supply and the rest of the panel is floating at about 15 amps max using 480 single phase on the line side of the 3KVA.
Just wondering if I can calculate exactly what the transformer is going to draw?
Carandorandy
Old 02-25-2011, 11:41 AM   #4
Rewards Points: 126
Ohms law is all you need to figure this out. Do you have an "ohms law" circle.
Here is what it looks like.
3 KVa / formula-ohmslaw-circle.jpg
Old 02-25-2011, 02:49 PM   #5
Electrician Canadian Eh!!
Carandorandy
More information is required.
480v single phase line side.
transformer connection type? single phase -> single phase?
What is the ratio of windings? (Will help to know the load voltage)
Once we know this then ohm's law will figue out the rest.
hhuggles is offline   Reply With Quote
Old 02-25-2011, 06:46 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you go and grab your little transformer slide rule thingy and look at what it says to use.
To be able to even look it up on a chart, you need the voltage and single or three phase.
Old 02-26-2011, 07:17 AM   #7
Oh, man. It has been a LONG time since I seen one of those slide rule thingys. 20 yrs since I had one of those.
Tags
kva , line side , rating.
Any Formula 1 (F1) or dirt track racing fans? concretemasonry Off Topic 10 02-13-2010 06:17 PM
Need a Formula Livewire78 Plumbing 7 12-13-2009 08:19 PM
bundle formula timothy918 Roofing/Siding 3 02-16-2009 05:36 PM
Formula for Main upgrade hogger9 Electrical 6 09-28-2008 11:02 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
