3 Gang Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 04:21 AM   #1
3 Gang Box
Hi -
I feel I know a decent amount about electrical work. I worked for an electrical for about a year, but that was 10 years ago. I bought a house a few months ago and i have been updating it. Its a 70's house so the electical is outdated. I just got done remodeling my kitchen and this week i have been installing recessed lighting. Every possible issue came up. 2x6 ceiling, wires running directly above the holes i drilled, the circuit runs the plugs in the home office. I think i have most of the issues worked out. My total wattage is still below 1400 as it it 14/2. My question is as follows. I added the recessed lights so i wanted a new circuit. I bought a dual slider and was going to put in into my 2 gang box. Turns out they used this box as a junction box. 5 wires are coming in already. I think as it its over the capacity. I bought a 3 gang box and will have three switches. However, i have never had a situation where i had more then 5 wires in a wire nut. My solution was to create two pigtails for the hot wire by doing the following:
Since i am using three dimmers, Two have wires only and the other one has screws. I am going to use the screw to feed power and the push in to pigtail to the other two plugs. Doing this i will only have 5 wires in my black pigtail and the neutral should be fine as well. Does this make sense?
jredling is offline   Reply With Quote
Old 11-06-2010, 07:50 AM   #2
I am not confident I am following, but I have learned a few things from this forum:
- it is bad to use the screw terminal on a switch to tie wires together. I am not certain that this is what you propose, but it sounds as if it might be. In my house, I have seen supply wires with insulation stripped mid-way towards the end, connected at the switch, leaving the remaining wire for use as a pigtail. I don't know if it is code, but it struck me as a safe option.
- there is a fill limit for wires and connections and devices for any given box. I believe it is based on volume of the box. What are the dimensions of yours (including depth)? Hopefully, one smarter than I can opine whether you have exceeded this.
oberkc is offline   Reply With Quote
Old 11-06-2010, 10:56 AM   #3
The box is big and deep capacity isnt a problem. I have a total of 6 wires in the box.
3 are wires to devices
1 is of course power
and the other two go to another room
I am using three dimmer, still have a lot of room
6 = wires = 12
ground = 1
dimmers = 6, i think
the box can go to 27.
What i am trying to do is find the best way to avoid having to many wires on a wire nut. The black wire would use up to 9 wires which is too many. I am trying to use two pig tail or run a jumper from switch to switch to cut down on the number of wires in the wire nut.
The white will have 6 wires, i think that is the max for 14-2, should i double pigtail this so i have 3 and 3 in a wire nut?
Old 11-07-2010, 07:16 PM   #4
I have seen, in my house, cases where a short section of insulation was removed from midway on a wire. This bare section was mounted under a device screw terminal, with the remaining wire continuing on to another device. I can't comment on whether that is code-compliant, but it seems to me a nice trick.
Perhaps something like that will reduce the number of wires in a wire nut. Otherwise, your suggested approach is one that I would take.
Old 11-07-2010, 08:43 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
What you propsoe is fine.
A note on dimmers.
As you add dimmers to the same box, they must be derated.
3 600 watt dimmers in the same box should be derated to 300 or 400 watts.
What is the total wattage each dimmers will have on it?
jbfan is online now   Reply With Quote
wiring a single gang and 3 gang box from one source twinkietrucker Electrical 4 02-17-2010 08:01 AM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 10:46 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 01:21 PM
3 gang switch or 3 way switch ?? explain with schematics vivek1406 Electrical 7 10-02-2008 06:54 PM
