3 Function Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 07:00 PM   #1
3 function switch
ok so i have my bathroom all wired up with my 20 amp dedicated branch. I have 3 functions that i want to be able to control so i got a 3 function switch. No on a piece of paper that came with it there are 4 columns. Model, Amps, Volts, and HZ. Under the columns it says P66W, 15/Rocker 20 total, 120, 60, respectively. NOW, is this 3 function switch gauged for 15 amps or for 20 amps?
bobward is offline   Reply With Quote
Old 08-25-2009, 07:15 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Ok let get this covered now.,,
Model number is P66W
Volts that usally max safe rated voltage it can be used in your case 120 volts
HZ mean Hertz or cycle per second and in North America it is 60 HZ so not worry about that one.
Now this get instering twist here
the amp rating you have two rating each switch are rated at 15 amp but you have second number is 20 amp so that mean you can use any three or all three switches on but the total load can NOT be over 20 amp
That how they rated this switch.
Merci,Marc
Old 08-25-2009, 07:31 PM   #3
well any way the breaker will trip.. merci
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
