Old 09-10-2011, 11:26 PM   #1
3 circuit relay
Hello,
I am vaguely familiar with AC/DC circuits. But I am not sure what I need or how to acchieve my newest idea.
I have RGB's on my motorcycle and I want to wire them for accent lighting and use them as turn signals.
I plan on using a toggle switch to go back and forth between the 2 setups.
For the turn signal it seems simple. I will wire the factory turn signal lead into one side of the toggle. When on it will supply 12V to all 3 RGB leads with the correct size resisters to create an amber glow.
The secondary is where I need help.
When switched on I need 3 separate circuits to go from open to closed. These 3 circuits are from an RGB RF controller. There is one lead for each of the red, green, and blue.
I have considered some kind of relay, but I am not familiar with anything like this. Thanks
fiffer000 is offline   Reply With Quote
Old 09-11-2011, 12:18 AM   #2
3 circuit relay
I have found these relays http://www.omron-ap.co.th/product_info/LY/index.asp
Not sure if one of these is what I need and if one will work which one. I am not sure how to read the schematics.
I have posted an image of what I am looking for. I am not an engineer by any means. I drew this up in paint and it actually shows 4 needed circuits not 3.
Here is a relay that looks like it would work, but I would not know what the extra posts are for or which ones to use.
Old 09-11-2011, 12:34 AM   #3
Electrician
SD515's Avatar
3 circuit relay
13 & 14 are the coil terminals. 1/9, 2/10, 3/11, 4/12 are normally closed. 5/9, 6/10, 7/11, 8/12 are normally open, will close when power is supplied to 13/14.
If you want the lights on when power is supplied to the coil, use 5/9, 6/10, 7/11, or 8/12.
Kyle
Old 09-11-2011, 12:38 AM   #4
3 circuit relay
Thanks for spelling this out for me. This was exactly the information I needed!
Old 09-11-2011, 12:43 AM   #5
3 circuit relay
Can you help me out again and let me know the difference in the power needs in these 2 relays? Thanks in advance
Old 09-11-2011, 04:04 PM   #6
Electrician
SD515's Avatar
3 circuit relay
Doesn’t look like there’s much if any difference in the specs between the relays, except the LY4N-D2 has diode surge suppression.
http://www.datasheetcatalog.org/datasheets2/44/449350_1.pdf
Kyle
Old 09-11-2011, 04:50 PM   #7
3 circuit relay
What does that mean in every day dummy terms
Old 09-11-2011, 05:12 PM   #8
Electrician
SD515's Avatar
3 circuit relay
If you have one, or if they’re cheap, try one. Maybe hooked it up on the bench and test it before you actually put it on the bike. Make sure things work the way you want them to.
Kyle
4 way circuit to a 3 way circuit BigAtl Electrical 8 12-16-2010 02:59 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
