Old 02-14-2013, 12:46 PM   #1
3 blade 220v to 4 blade..Please help
I hope I'm posting this in the right area.I appreciate any input as I have no knowledge in electrical.I have a concrete floor grinder that requires 220v to run.My plan was to hook it up to my 5500 watt generator in the 120/240v outlet.My dilemma is that the plug on the machine is a 3 blade and the the generator takes a 4 blade connector.Can I swap the plugs out ? If so what wires go where? thanks for any help...
Cee1281 is offline   Reply With Quote
Old 02-14-2013, 01:08 PM   #2
Electrical Contractor
kbsparky's Avatar
Simply omit the neutral conductor on a new NEMA L14-30P cord cap.
-KB
Old 02-14-2013, 08:02 PM   #3
Thanks for the reply, so just to make sure I understand..Im going to use the 3 wires off the 3 blade connector and connect them to the L14-30P cap,so ill have a ground wire and the other 2 wires connected to the new cap but not using the neutral at all? Does that make sense..
Lastly what blades does the wires hook up to on the new cap, I know one blade has a L shape to it...
thanks for your help
Old 02-14-2013, 08:41 PM   #4
Electrical Enthusiast
thanks for your help[/QUOTE]
The L-shaped one is the ground connection, it should be a bare or green-colored wire.
The two prongs to the left and right of this are your two hot connections, the other two wires will connect to this. The prong across from the ground (L-shaped) prong would be the neutral, which you aren't using in this case.
Kyle_in_rure is offline   Reply With Quote
Old 02-15-2013, 09:07 AM   #5
Master Electrician
You got that dead wrong.
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
Old 02-15-2013, 11:08 AM   #6
Mark
Can you please elaborate, just want to make sure I'm doing this correctly, I don't want to mess nothing up....
What's the correct way?
Old 02-15-2013, 11:48 AM   #7
Mark
Are you sure?
We are talking a bout a L14-30P, correct?
And since it's 240 volts, 3-wire, there's no neutral, it would be omitted, correct?
This is the plug we're talking about, correct?
http://www.bing.com/images/search?q=...electedIndex=5
Hope I'm not misreading....
Old 02-15-2013, 12:46 PM   #8
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
With an L14-30 plug the two hots go on the brass screws and the ground goes to the green screw. Leave the silver neutral screw empty.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-15-2013, 01:06 PM   #9
I bought a 4 blade plug and it has L14-30P on it, so I'm assuming that's what I need...
Old 02-15-2013, 01:24 PM   #10
Master Electrician
The L shaped blade is the neutral.
Mark
Old 02-15-2013, 01:33 PM   #11
Master Electrician
I'm sorry. The OP wasn't clear. Does the generator have a locking receptacle or not. My comment was directed at non-locking. I don't know that I would say the blade on a locking plug is exactly "L" shaped.
I missed the second OP post that specified locking.
Mark
Old 02-15-2013, 07:08 PM   #12
rrolleston's Avatar
Mark
Where do you get your L14-30 plugs and receptacles. The L shaped blade is the ground.
Old 02-15-2013, 07:45 PM   #13
MarginallyQualified
The L shaped blade is ______
Mark
sure?
Old 02-15-2013, 08:13 PM   #14
Gotta love those twistlocks....
Old 02-15-2013, 09:03 PM   #15
Master Electrician
Originally Posted by TarheelTerp View Post
sure?
It doesn't look like an L to me.
Mark
How many Tooth Saw Blade for Trim? HandyFrank Carpentry 11 12-28-2011 08:11 PM
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 02:16 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 05:26 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
