Old 04-04-2009, 04:07 PM   #1
3 Black, 3 White, I'm clueless about Fan Replacement
I am replacing a ceiling fan. The new Minka Aire fan/light has a ground, black and white... the previous installation had ground + 3 black + 3 white. I wasn't that careful when I uninstalled the old fan, but I recall that at least one of the black and whites were spliced together.
What is the best way to sort this out. I took a guess is which black and white combination was correct, but since there are so many possible combinations, I'm not sure best way to work my way through this.
I would assume that if I had some sort of tester, I'd be able to determine which ones were live and which are not. Is there a simple device and procedure that would allow me to determine which ones are I should connect to?
I'm completely green about this....
kendor is offline   Reply With Quote
Old 04-04-2009, 04:17 PM   #2
Let me start by saying
When you say 3 black, 3 white....are you counting the fan wires in this number?
220/221 is offline   Reply With Quote
Old 04-04-2009, 04:22 PM   #3
3 black and 3 white from the box + ground. The fan/light combo only has 1 black + 1 white + ground.
Old 04-04-2009, 04:25 PM   #4
Take apart the switches and describe the wiring.
A fan/light shoud have one more wire ???
Old 04-04-2009, 05:36 PM   #5
as seen on tv
switch loop power to fan back to switch?
qbert is offline   Reply With Quote
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 10:24 AM
What colour to paint my white and black bathroom LindaC Interior Decorating 6 01-07-2009 06:59 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Black White and Red CTH Electrical 6 04-02-2008 12:46 AM
black to black, white to ground? klassa Electrical 4 02-10-2008 08:38 AM
