#3 AWG Copper SER / PVC Conduit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 09:46 AM   #1
Hi! I have a new meter panel I put in and am replacing a cable for a 100 AMP subpanel. I am using 2" PVC from the attic eave down to the panel with two LB's. The total run in conduit is about 5 feet only to protect the cable. I am also running #6 SEU cable for my furnace in the same conduit. My question is this - do I need to remove the sheathing from the SER and SEU cable when it is in the conduit? Would it make pulling it in the conduit (around the LB bends) easier? Can I also fit 10-3 for my dryer and 10-2 for my hot water heater in this same piece of conduit, and if so, can/should the sheathing need to be removed on that as well? Thanks for your help!
djejay75 is offline   Reply With Quote
Old 12-08-2008, 01:02 PM   #2
Rewards Points: 160
Do you mean service panel? Sub panels are after the main service. (second panel) You cannot mix service entrance conductors with other wiring.
Old 12-08-2008, 01:44 PM   #3
I have a main combination meter/panel outside, then a 100 AMP breaker in that panel feeding a panel in the interior of my home.
Old 12-08-2008, 06:08 PM   #4
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Removing the sheathing is illegal (using the cable with it removed). That cable is not rated to be used without the sheathing. The only place it can be removed is where it terminates and junctions.
Jamie
jamiedolan is offline   Reply With Quote
Old 12-11-2008, 11:40 PM   #5
" Euro " electrician
frenchelectrican's Avatar
You can not do this due you will allready run into code related issues.,
removeing the sheathing from the SER and SEU will lead some issue with it the other thing do not think about run the 10-3 and 10-2 with this due the derating factor will kick in no question asked.
Merci,Marc
Electrical size conduit question pauls Electrical 12 12-03-2008 09:22 PM
PVC Conduit and steel box Question???? houstonbrama Electrical 4 08-07-2008 11:56 AM
Barn wireing and conduit question???? houstonbrama Electrical 8 07-09-2008 01:12 AM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 03:55 PM
Copper pipe for conduit? ricemg Electrical 4 01-23-2007 05:04 PM
