2x3 Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2010, 01:03 AM   #1
Talking
2x3 studs
i have #12 wire between 2X3 studs, can someone tell me if there are special box's that allow to wire a switch. The 2X3's make it very tight to work in.
pit495 is offline   Reply With Quote
Old 12-25-2010, 07:39 AM   #2
Yes, there are boxes for 2x3 studs. But pay attention to box loading charts, not too many wires please. Plastic boxes will often list how many wires are allowed, or consult NEC.
Something that is often done with smaller boxes is to use a double gang box with a single fixture cover. Gives lots more working space.
Old 12-25-2010, 08:31 AM   #3
joed's Avatar
Rewards Points: 11,598
If the cables are fed though holes in the studs you also need metal plates over the cables to protect them from nails and screws.
Old 12-25-2010, 11:03 AM   #4
I have the exact same problem. Check out this thread for some solutions:
Counting wires in a box?
jerseyguy1996 is offline   Reply With Quote
Old 12-25-2010, 04:49 PM   #5
Thank you all for the quick response, looks like JerseyGuy has what I need. Since the switch box is in a tile bathroom the Lowe's box with the side extension should work perfect.
Thank you all
AND
Merry CHRISTMAS
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
