2way Switch Earthing - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 08:56 AM   #1
2way switch earthing
I would like to install a 2 way switch in with an alread exsisting 1way switch I believe that under the new regs the cable should be a 3 core and earth cable however there is a already an earth conductor with the 1way switch so my question is may I now use twin and earth as the link as before
Heve is offline   Reply With Quote
Old 04-22-2012, 09:05 AM   #2
Rewards Points: 150
O.K. I think I got the core = conductors
earth core = equipment ground conductor
1 way sw = single pole toggle
2 way sw. = a three way or a double pole/double throw ?
Jeeps is offline   Reply With Quote
Old 04-22-2012, 09:39 AM   #3
joed's Avatar
Rewards Points: 11,614
You can't wire 2 way switches with 2 wires. Three wires are needed to make the switches work properly. You can't use the earth/ground wire as one of the switching wires.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
