2nd Wiring Problem Condo - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 05:45 PM   #1
Rewards Points: 240
2nd wiring problem condo
Hi again,
In the dining room we have dimmer switch when I open the switch we have 2 black wires into the switch. The blacks are connected via caps to a red and yellow wire (jumpers?) and the two white wires are capped together.
So the switch has two black wires only and there is no ground (bare wire or green wire)
If I want to install Lutron vacancy dimmer switch would I add the green to the white capped wires and each black to the red/yellow and bare wire on the Lutron to a screw into the box?
thanks
dfphoto is offline   Reply With Quote
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Wiring problem datoda Electrical 6 12-28-2009 07:43 PM
Home wiring problem CAD Electrical 8 10-17-2009 02:26 PM
Problem with Air Handler wiring connection to Outdoor Unit & Thermostat miamikk HVAC 0 09-29-2009 07:02 PM
