2nd Main Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 11:03 AM   #1
Rewards Points: 27
2nd Main disconnect
My electrical panel does not have a main disconnect. The disconnect is located outside at the meter. There is spot to add a disconnect in the panel. Is there a problem adding a second disconnect in the panel. I was hoping to add a generator and I need the interior disconnect to install the interlock kit.
jodywoj is offline   Reply With Quote
Old 03-17-2013, 11:15 AM   #2
Rewards Points: 12,830
Post a picture of the panels.
Is this a mobil home?
Old 03-17-2013, 12:06 PM   #3
Master Electrician
Rewards Points: 3,678
There is no problem with a second main. Why not install the interlock on the exterior disco?
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
stickboy1375 (03-17-2013)
Old 03-17-2013, 12:13 PM   #4
Rewards Points: 27
It a four bedroom home in the Keys. I figure it would be easier to install the disconnect and interlock on the main panel. I didn't know an interlock could be installed on the main disconnect outside. No pics, but it's a Square D QO panel, 40 space I believe.
Old 03-17-2013, 02:03 PM   #5
Master Electrician
Not knowing what type od disco is outside an interlock may not be possible. It just makes more sense to me as the gen must be outside anyway and the gen connections should be shorter and easier to install.
disagreement on main lug vs main breaker n175h Electrical 38 04-12-2012 09:21 PM
Question about main panel grounding ACR_SCOUT Electrical 9 01-15-2012 11:24 PM
Panel Main Disconnect flatlander745 Electrical 4 10-05-2010 11:13 PM
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 09:08 PM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 11:02 AM
