2Gang Cover For 30 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 10:51 PM   #1
Rewards Points: 290
2Gang Cover for 30 Amp
I've looked everywhere online...
Can't seem to find a combo that will do the trick just short of a mud ring adapter...
I have a 2 gang Box flush with my outside wall.
I would like to put any variant of a L14-30 outlet in there.
However, I've yet to see any cover meant for a 2 gang.
The closest thing I came up with is to buy a 2 gang cover that has a hole for a single. However, the single hole is a hair smaller in diameter than speced for a L14-30. So no NEMA standards but I would just bore the hole slightly bigger so the outlet would fit. I DON'T know after boring it, if the flap cover will be good but I suspect so....I'm increasing it by a couple of cm...
Anyone have any other ideas on how to get a L14-30 into a 2 gang exterior box. At this point, I don't care if it's Locking, Non Twistlock, inlet, etc.
mobiledynamics is offline   Reply With Quote
Old 12-20-2012, 05:53 AM   #2
Master Electrician
Rewards Points: 3,920
2 gang weatherproof covers should be readily available at an electrical supply house.
brric is online now   Reply With Quote
Old 12-20-2012, 05:56 AM   #3
Rewards Points: 290
But the question goes is who makes one that will fit ideally a L14-30
Old 12-20-2012, 06:03 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Many of the common weather proof in-use covers have knock outs for different sized single receptacles.
If you look around the switch in this area, you will see concentric circles. If you only have this one device in the 2G box, then just install install a blank switch on the other side.
Old 12-20-2012, 08:07 AM   #5
Rewards Points: 290
So far, the in use variants I've looked at, the diameter for a round recp. Max Diameter is the 1.46 variant. Not the larger 1.55 for the 30 amp turnlock
Old 12-20-2012, 04:54 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
I've never seen such an animal. Not for an L14-30 at least.
Why would you need such a thing? PLEASE don't tell me you are making your own generator inlet using a suicide cord.
Old 12-20-2012, 06:29 PM   #7
Master Electrician
[quote=mobiledynamics;1076560]But the question goes is who makes one that will fit ideally a L14-30[/quot
Hubbell, for one.
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Cover modification for older Murray service panel JeffT Electrical 2 05-29-2012 10:43 PM
HELP for simple patio and patio cover 1st time crzysprstr Building & Construction 8 05-29-2012 10:00 PM
removing wall vent cover help numpty HVAC 4 05-03-2012 07:00 AM
Floor Drain Cover - Advice? globus999 Plumbing 2 07-23-2010 10:40 PM
