2ft Wall/Hallway Electrical Outlet Question?? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 08:27 PM   #1
Post
Hi there,
I am finishing off a basement and adding a bedroom with bathroom and entry hallway. I know and understand the one outlet every 12ft, one outlet for hallways over 10ft, and one outlet for walls over 2ft rules. However, the entry hall has a cut out that is 2'3" x 5' for a table where we plan to put a lamp. Is it ok to put just one outlet on the 5' wall and not worry about the two side walls, or am i required to put outlets on the two side walls because they are over 2ft?? BTW one of the 2'3" walls is on the same wall as the doorway to the entry hall, if that makes any difference.
Any help would be greatly appreciated.
Thanks!!
hatchekc is offline   Reply With Quote
Old 07-17-2010, 08:51 PM   #2
Electrician
Proby's Avatar
Originally Posted by hatchekc View Post
Hi there,
Thanks!!
That's perfectly fine.
Proby is offline   Reply With Quote
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 03:31 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
