277v-120v Transformer Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 08:34 PM   #1
277v-120v transformer problem
I have a 277 volt to 120 transformer that is only pulling 28 volts. Why? Its a single phase 277
robj116 is offline   Reply With Quote
Old 08-02-2011, 08:58 PM   #2
I=E/R
a7ecorsair's Avatar
If you have 277 feeding it and 28 coming out, I'd think the TX is bad.
a7ecorsair is offline   Reply With Quote
Old 08-02-2011, 09:41 PM   #3
Rewards Points: 77
Need a little more info to help you out there bud. Could be many reasons why. We all like pictures or at least some more info.
CheapCharlie is offline   Reply With Quote
Old 08-02-2011, 10:31 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Possibly you're reading one of the 120V legs to ground and it isn't bonded?
Where is the 28 volts appearing? Is there any load on the 120V side? Is it an electronic transformer or core-and-coils?
micromind is offline   Reply With Quote
Old 08-02-2011, 10:45 PM   #5
more info
does the transformer need a ground. all we are using is the power lead to the primary side. I get 278v but when I meter the secondary side the best I can get is 28 volts.
Old 08-02-2011, 11:00 PM   #6
the 28 volts is appearing on the opposite pole from the 277 lead. There is no load on the secondary side.
Old 08-02-2011, 11:02 PM   #7
It is also a coil transformer
Old 08-03-2011, 12:08 AM   #8
" Euro " electrician
frenchelectrican's Avatar
What wattage the transfomer is and I am pretty sure you have a shorted coil or somecase semiopen coil which the result that you are reading low voltage on secondary side.
Merci,
Marc
Old 08-03-2011, 01:48 AM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,920
Exactly what two points are you reading 28V between? Is that from ground to one of the secondary leads? If so, the problem is that the secondary is floating and not bonded to ground. Measure between the two secondary leads. You have to ground one of them.
mpoulton is offline   Reply With Quote
Old 08-03-2011, 09:03 AM   #10
I=E/R
a7ecorsair's Avatar
If you have two primary leads on the transformer and two secondary leads on the transformer, you do not need any grounding to see the output voltage. If you want additional feedback I think you need to give us a better description of the setup. What is the potential use of this transform? How big is it? How about a picture
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
Outdoor lighting transformer problem lindapalmbay Landscaping & Lawn Care 2 09-16-2009 08:18 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Convert 277v to 120v tricks? Fux39 Electrical 16 11-26-2006 08:17 PM
