277 V Fixture Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 08:33 AM   #1
277 v fixture question
Why does a 277 v fixture only uses one hot wire ,neutral and ground shouldn't it use two hots instead?:/
RAUL HIDALGO is offline   Reply With Quote
Old 08-26-2013, 08:37 AM   #2
Rewards Points: 150
The white wire should be marked black to indicate its a hot wire too. What kind of fixture are you using
romex1220 is offline   Reply With Quote
Old 08-26-2013, 08:42 AM   #3
This is the fixture in question. I understand that the white should be black but when I touched the white wire there was no power on it( that's to say I didn't got schocked)
Old 08-26-2013, 08:45 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
277 volts is part of a 3 phase 480 wye configuration whereas, each phase to neutral/ground is 277 volts.
So there isn't "2 hots".
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
RAUL HIDALGO (08-26-2013)
Old 08-26-2013, 08:48 AM   #5
Finally I get it now ,thank you very much sir, now that I think about it there are some transformers inside the building ,it all fits now
Old 08-26-2013, 09:16 AM   #6
Rewards Points: 150
Sorry, for what ever reason I was thinking 240 volt with two hots. I forgot about the three phase 480
Old 08-26-2013, 09:42 AM   #7
Rewards Points: 1,010
"Forgetting" is a poor excuse for giving out information that is both wrong and dangerous
Anti-wingnut is offline   Reply With Quote
The Following 2 Users Say Thank You to Anti-wingnut For This Useful Post:
Philly Master (08-27-2013), Speedy Petey (08-26-2013)
Old 08-26-2013, 01:38 PM   #8
It's because the hot wire is 277V if you had 2 hots that would make it 480V. it has to do with the transformer suppling the building in residential the transformers only supply 120/240 in commercial with different trans formers they are 277/480 a Y transformer 3phase each leg carries 277V. it get a little complicated to explain
1cashking is offline   Reply With Quote
Old 08-26-2013, 02:00 PM   #9
Rewards Points: 510
480/1.732 (square root of 3) is 277.
Piece-o-cake
jbfan (08-26-2013)
Old 08-26-2013, 02:13 PM   #10
Rewards Points: 150
I'll just stick with residential wiring
Old 08-27-2013, 01:49 AM   #11
yes it could be complicated 120/240 is from a 3phase delta transformer with no stinger if it had a stinger leg 120X1.5=180V it would be tapped from between 2 hots to ground at the transformer used mainly for industrial heavy motor loads. this takes me back to my school days. Thanks for making my brain work again!
Old 08-27-2013, 04:14 PM   #12
Electrician
Rewards Points: 802
Are you working on 277V lights in a commercial or industrial setting? If so that is not DIY work.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Oso954 (08-27-2013)
Old 08-27-2013, 07:19 PM   #13
Don't worry , yes I was installing the fixtures but under the supervision of a master electrician and the question just came to mind, however not everyone is so willing to answer like you guys.
Old 08-27-2013, 07:29 PM   #14
An old Tradesmen
Rewards Points: 7,802
277 is a nasty voltage to work with. Mostly because people seem to want to treat is like 120 volt. Not realizing that 277 doesn't like to give people a second chance.
I've seen guys get lucky with it though. One guy, it went in his elbow, and blew a hole in his middle finger where it was touching a neutral. No blood though. it was 2 weeks before it started to bleed.
So please, be careful.
Old 08-27-2013, 07:40 PM   #15
I always treat every installation like its energized even if I'm asured its not, however in these case it was live so I was extra careful( if such a thing exists ) thanks though.
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 07:46 AM
Replace outdated fixture with outlet derbydog Electrical 4 12-14-2011 12:53 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
New fixture wiring question Unregistered Electrical 1 02-22-2004 07:34 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
