250v Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 10:54 PM   #1
Rewards Points: 12
250v outlet
Hello members;
I have a 15a 250v duplex outlet. Instead of the typical 2 brass + 2 silver , 1 green terminals screws seen on a regular 120v recepticle it has 4 brass terminal screws ( 2 on each side) and 1 green screw.
Since this this 15/250v outlet is wired with 12/3 wire how is this wired?
Regular 120v recepticle when there is 1 hot it goes to brass, neutral(white) to silver and copper to green terminals.
250v recepticle has 2 hots, 1 neutral and ground.
Thank-you for your help
BN
BlkNotes is offline   Reply With Quote
Old 04-17-2013, 10:57 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There should be a wiring diagram included with the device. I'd take a look at that first.
Old 04-17-2013, 11:03 PM   #3
Rewards Points: 12
No wiring diagram. It's a hubbell p-2356 . Tried looking for one online but no luck.
Old 04-17-2013, 11:08 PM   #4
k_buz's Avatar
From what I saw of this device is it is a 250V (only device). Which means it only has connections for the two hots and the ground. If what you are plugging into this device requires a neutral, this device will not work.
If the load does not require a neutral, this device is like a standard 120V receptacle. One phase to each side of the device, and ground to the green (ground) screw.
Old 04-17-2013, 11:24 PM   #5
Rewards Points: 12
So would I just cap off the neutral if the device does not require a neutral?
So 1 hot to upper brass screw and second hot to lower brass screw?
Old 04-17-2013, 11:30 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Woah hold on that one.,
Is that the one you are refering to this receptale ?
If so you can not use the upper and lower screw on the same side otherwise it will result a direct short circuit which that is very dangerous.
The correct way is take one hot conductor on one side ( brass screw ) and the other hot conductor on the other side of brass screw and green or bare conductor on green screw that it.
The red or black conductor it don't matter which way it will be as long one at each side of the receptale.
Merci,
Marc
Old 04-17-2013, 11:42 PM   #7
Rewards Points: 12
Yes thats the outlet. i think it has been updated to the hbl 4550.
http://www.stayonline.com/documents/5867-pdf.pdf
What do I do with the white ( neutral) wire left over from the 10/3 cable?
Old 04-17-2013, 11:43 PM   #8
k_buz's Avatar
I have been trying hard to simply answer the questions posed, but in this case, I have to ask what you plan on plugging into this receptacle?
The Following User Says Thank You to k_buz For This Useful Post:
frenchelectrican (04-17-2013)
Old 04-17-2013, 11:45 PM   #9
Just cap it off with wirenut on it. ( white conductor )
I been wonding the same question as K_Buz ask ya.
Merci,
Marc
Old 04-17-2013, 11:53 PM   #10
Rewards Points: 12
A dust collector and a bandsaw feeder
http://www.deltamachinery.com/produc...nt/item/50-760
http://cdn0.grizzly.com/specsheets/g1094_ds.pdf
Old 04-17-2013, 11:59 PM   #11
k_buz's Avatar
Take a look at the literature that comes with the dust collector...
Be sure the 240 volt plug is only used in an outlet having
the same configuration as the plug illustrated in Fig. C.
What you have and what is shown in the manual are not the same.
Old 04-18-2013, 12:07 AM   #12
Rewards Points: 12
It is the same plug but mine is in twist lock configuration instead of flat blades. Both are 15a 240v
Old 04-18-2013, 12:12 AM   #13
Both machines ?
I know I did read the PDF files which you left a link so the dust collecteur use the 15 amp 240 volt flat blades from factory.
So unless you are changing the plugs to the twistlockers is that right ?
Merci,
Marc
Old 04-18-2013, 12:19 AM   #14
Rewards Points: 12
Correct, i am changing the plugs to matching twist lock as well . trying to minimize plug pop out.
Old 04-18-2013, 12:49 AM   #15
k_buz's Avatar
According to manufacturer specs, you are not allowed to do that and will void any warranty on the equipment.
Outdoor Outlet seansy59 Electrical 3 03-09-2012 03:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
