250v 50A Stove Plug Convert To 240v 30A For Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 11:20 AM   #1
250v 50A Stove plug convert to 240v 30A for dryer
Hi All,
I just purchased a new dryer / washer and went to plug it in and found the plug is different from the one needed for the dryer.
Presently the wall receptacle has written 250v, 50A. By tracing to the breaker box the switch is a 40 A switch.
I need to convert this to a 240v, 30A receptacle to make my dryer work.
Does any other work need to be done other than to switch the receptacle cover ?
Thanks,
wololo696 is offline   Reply With Quote
Old 12-31-2012, 11:25 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
The breaker would need to be changed to 30 amp.
Do you have a 3 or 4 wire feed?
Old 12-31-2012, 11:32 AM   #3
Rewards Points: 80
You need to change the receptacle too. Wire is fine as long as it's #10 or larger.
Old 12-31-2012, 11:50 AM   #4
Thanks for the fast responses. How would I tell if the wire is #10?
Old 12-31-2012, 11:58 AM   #5
jbfan's Avatar
Rewards Points: 240
If you can read the jacket of the cable, it will tell you the size.
Old 01-01-2013, 01:30 PM   #6
Rewards Points: 240
Also, you can get a little plastic template thing that will tell you the gauge of the wire. Most of the big box stores have them.
fa_f3_20 is offline   Reply With Quote
Convert plug to light fixture? MeasureThrice Electrical 2 11-26-2009 10:19 PM
30A 240v plug Red Squirrel Electrical 3 07-22-2009 01:48 AM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
30a/240v convert to RV plug rsplash40 Electrical 8 05-09-2009 05:38 PM
convert plug in light with screw in hornet1946 Electrical 5 01-31-2008 07:00 PM
