-   -   250v 50A Stove plug convert to 240v 30A for dryer (http://www.diychatroom.com/f18/250v-50a-stove-plug-convert-240v-30a-dryer-167860/)
wololo696 12-31-2012 11:20 AM
Hi All,
I just purchased a new dryer / washer and went to plug it in and found the plug is different from the one needed for the dryer.
Presently the wall receptacle has written 250v, 50A. By tracing to the breaker box the switch is a 40 A switch.
I need to convert this to a 240v, 30A receptacle to make my dryer work.
Does any other work need to be done other than to switch the receptacle cover ?
Thanks,
jbfan 12-31-2012 11:25 AM
The breaker would need to be changed to 30 amp.
Do you have a 3 or 4 wire feed?
J. V. 12-31-2012 11:32 AM
You need to change the receptacle too. Wire is fine as long as it's #10 or larger.
wololo696 12-31-2012 11:50 AM
Thanks for the fast responses. How would I tell if the wire is #10?
jbfan 12-31-2012 11:58 AM
If you can read the jacket of the cable, it will tell you the size.
fa_f3_20 01-01-2013 01:30 PM
Also, you can get a little plastic template thing that will tell you the gauge of the wire. Most of the big box stores have them.
