Old 10-02-2012, 01:17 PM   #1
250V 30amp 3 post plug on a bandsaw, change the plug to a 4 post plug question
Hello-
I am a woodworker, I have a small electrical dilemma to pose: I am working on a building project and I haven't hooked up the electrical service on site yet. I have a 17" Bridgewood bandsaw that runs on 220V power, it has a plug labeled 250V/30A. I would like to use this machine to cut some beams, but as I don't have service in the building yet I am hoping to use my Yamaha generator to power the bandsaw. the generator has a 220V circuit that has a four post outlet, but the bandsaw's plug is only a three post. I understand that when you have a balanced load, as in the motor of the bandsaw, there are only two hots and a ground used on the circuit. I took the saw's plug apart and found two hots labeled X and Y, and a green ground wire (3 wires). I have a new four post plug that fits the generator's outlet, but there are four connections in the plug, W, X and Y, and ground. Is it safe to hook up this plug up to the bandsaw motor with only the X and Y hots and a ground? I don't want to risk doing anything that wouldn't be safe and possibly damage the bandsaw... I'd appreciate any advice from someone who is more knowledgeable about these matters than I am. thanks.
benjeremiah is offline   Reply With Quote
Old 10-02-2012, 02:39 PM   #2
Semi-Pro Electro-Geek
The fourth (neutral) terminal of the generator receptacle is only required for loads that use both 120V and 240V. Your saw is a 240V-only load, so you can just leave the neutral (W) terminal empty when wiring the plug to the saw. No problem.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-04-2012, 10:06 AM   #3
Hey thanks for the reply mpoulton, I wired the plug yesterday and I will soon be cutting my beams with the bandsaw running from the generator. they are about 8" x 10" and some are 16 ft. long... I need to cut them down to 6" x 9" to make some supports for floor joists that are going to make a storage loft for my woodshop. thanks for the advice.
Old 10-04-2012, 12:43 PM   #4
Nice project. Have fun!
Tags
220v circuit, bandsaw, generator, motor
