250ft Underground Run From House - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 01:13 PM   #1
250ft Underground run from house
Greetings,
This is my first post and i have found much i have read to be very useful. I am wondering if anyone could give me the necessary wire sizes and best way forward to do the run myself and have someone else to do the hook up. I would like to have enough power to run a small fridge, lights and ceiling fan.Also, Can I run CAT5/6 if it is shielded in the same conduit and when can I use PVC? I know it is a lot, but I trust you more than most. Thanks for any input.
Jguckert is offline   Reply With Quote
Old 11-10-2010, 03:50 PM   #2
If you are going to have someone else do the hook up why not ask them what you need? You cannot mix low voltage wires in the same conduit as house voltage. If you are burying the pipe then pvc would be the way to go but make sure you glue the sticks together well. Using a voltage drop calculator for a 20 amp circuit at 250' you need #4 awg cu. You would need 1" pvc to hold three #4 thhn awg cu.
lordlondis is offline   Reply With Quote
The Following User Says Thank You to lordlondis For This Useful Post:
Jguckert (11-10-2010)
Old 11-10-2010, 05:45 PM   #3
Thank you
Makes perfect sense. Thanks so much. Have a good one.
Old 11-10-2010, 05:49 PM   #4
Rewards Points: 324
you need a ground wire also...#6
oleguy74 is offline   Reply With Quote
Old 11-10-2010, 05:54 PM   #5
Good Point. I appreciate that...
Old 11-10-2010, 06:25 PM   #6
Rewards Points: 324
wire needs to be thwn.
Old 11-10-2010, 07:25 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you should run wet rated cat 5/6 also.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
My house progress so far - over the years Snav Project Showcase 5 05-06-2015 12:11 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
