24vDC To 12vDC - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 02:53 PM   #1
24vDC to 12vDC
Hi,
I have a Cat excavator and I want to put a radio in it. The machine runs off 24vDC and I tested off the switch and it is also 24vDC. I was looking at some voltage converters (5 amp). But I was wondering what others would recommend on what I could do. Thanks.
nates90 is offline   Reply With Quote
Old 01-07-2013, 02:56 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
http://www.sears.com/shc/s/p_10153_1...=35-22584447-2
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-07-2013, 03:02 PM   #3
Rewards Points: 14,312
Does it have two batterys?
Just wire it up to one of them.
Old 01-07-2013, 03:04 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,990
The converter is a great solution and probably the best idea. However, a simpler way is to just connect the radio to one of the excavator's two batteries. 24V heavy equipment uses two 12V (or sometimes four 6V) batteries in series. If you tap off of the first battery, you get 12V. This results in uneven load between the two batteries, thus slightly overcharging the other battery - but if the load is small (like a stock car stereo) then this will not cause any problems. Be sure to use an appropriately sized fuse placed as close to the battery terminal as possible.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
120vac temp-switch running on 12vdc Crossedivide Electrical 1 09-22-2012 05:11 AM
How do I run a 24vdc solar attic vent with 120vac? czissman Electrical 11 03-25-2012 06:35 AM
12vdc 240vac in same outdoor weatherproof junction box ron351 Electrical 3 07-28-2011 11:16 AM
12V DC lighting? pcampbell Electrical 3 10-28-2008 09:57 AM
