240v Vs 120v Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 05:21 PM   #1
Rewards Points: 150
240v vs 120v connection
Originally Posted by codeone View Post
Some could be, however alot of code changes are due to safety issues. Example: 3 wire vs 4 wire on a druer and range. Also sub panels 3 wire to 4 wire.
In school 40 yrs ago they taught electricity is trying to find ground, not true its trying to find its source, it can go through ground to get there. It also takes all paths available to it to get there, Thats why grounds and neutrals are seperate in subpanels today.
Jus a few examples with not knowing any reasons for the recall.
Not trying to change the question and information at hand
But when you say four wire is it
two hot
one neutral
one ground??
The hott are they normally black and red correct?
canyonbc is offline   Reply With Quote
Old 01-12-2010, 05:25 PM   #2
two hot
one neutral
one ground??
Correct
Black and red= ungrounded conductors(hot)
White= grounded conductor (neutral)
bare copper or green= Ground wire
Paelectrican is offline   Reply With Quote
Old 01-12-2010, 05:38 PM   #3
Rewards Points: 150
Originally Posted by Paelectrican View Post
Correct
Thank you
Now I must ask why two hot conducting wires?
Is there a certain order you want to have the black and the red?
Old 01-12-2010, 05:46 PM   #4
Thank you
This is where you get 240 from, the red provides 120 and black provides 120. No there is no order.
Old 01-12-2010, 08:13 PM   #5
Rewards Points: 150
Thank you, that makes a lot of sense.
Mike
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 11:29 AM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
2008 NEC - 120V and 240V receptacles on the same MWBC? ScottR Electrical 10 06-05-2009 10:39 PM
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 09:15 AM
