240v Thermostat On 120v System? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 09:33 AM   #1
heinlein0311's Avatar
Rewards Points: 81
240v thermostat on 120v system?
I am installing a 120v radiant floor heat system in my bathroom. I already have a 240v thermostat that is for radiant floor heat. Can I use this thermostat if I wire it the same as I would for a 120v thermostat? Instead of 2 leads, just wire the one?
heinlein0311 is offline   Reply With Quote
Old 03-11-2013, 09:37 AM   #2
Rewards Points: 992
Don't know if it works on all thermostats or not, but I cut a baseboard heater from 240 to 120 and the thermostat worked just fine.
I just changed it at the breaker box; the rest of the wiring remained as it was.
Toller is offline   Reply With Quote
Old 03-11-2013, 10:39 AM   #3
Rewards Points: 240
You can wire it with one lead (hot) or both hot and neutral.
Old 03-11-2013, 11:09 AM   #4
Rewards Points: 1,548
The 240 volt line voltage thermostat works perfectly well on a 120 volt circuit.
The reverse is not true. A thermostat rated for 120 or so volts may not have both hot leads of a 240 volt circuit connected to the thermostat unit even if there is a neutral giving 120 volts hot to neutral.
Old 03-11-2013, 11:19 AM   #5
Rewards Points: 81
Awesome, thanks guys for the good info, it's well appreciated!
Old 03-11-2013, 12:28 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,990
If it is an electronic thermostat it probably will not work. If it is non-electronic, then it should be fine.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 03-13-2013, 05:42 PM   #7
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
The GFI probably won't work either....
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Looking for some help with 240v to 120v wiring Tyrus3 Electrical 4 06-07-2012 09:28 AM
Totaline wireless thermostat not showing the correct temperature and system not cooling upper floors phuheey HVAC 3 06-01-2012 05:52 PM
240v Air Compressor to 120v help ruacoltsnut General DIY Discussions 10 11-11-2010 04:05 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
A/C won't turn off with thermostat temp adjustment ( Goodman system ) rkpatt HVAC 3 07-29-2008 04:58 PM
