240v Sub Panel Hook Up With No Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2008, 03:56 AM   #1
Question
240v sub panel hook up with no neutral
Recently a friend and I have been doing some remodeling on my garage. We decided to hookup a 240 sub panel from the main house. We strung some jacketed #8 wire in conduit from the main panel to the new sub. There are three wires in the jacket: a white one, a black one and a bare copper one. The power is coming from the main panel from a two pole 50 amp breaker. We used the white and black wires as the two hots and lugged it to the two buses in the sub for 240v. It works but as I was drifting off to sleep just now I realized I donít have a neutral wire in the Sub panel. Is this an accident waiting to happen? What should I do?
ut74 is offline   Reply With Quote
Old 03-07-2008, 05:21 AM   #2
When is fishing season?
CowboyAndy's Avatar
You NEED to have a 4 wire feed for the sub panel, 2 hots 1 neutral and 1 ground. Is this in an attached building (garage) or a detached building (shed, workshop)? You need to have the neutral and ground seperated in the sub panel, not bonded together. you also need a ground rod as well if it is in a detached structure.
#8 needs to be breakered at 40AMPS as well.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-07-2008, 05:45 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Wow. I'd get a few good books on home wiring and get the rudimentary basics down before doing ANY more electrical work.
This is NO place to fool around of you don't know what you are doing.
Speedy Petey is online now   Reply With Quote
Old 03-07-2008, 10:17 AM   #4
Thanks for the help! Disconnecting and calling electrician.
Old 03-07-2008, 10:20 AM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Originally Posted by ut74 View Post
What should I do?
Turn it off until you redo it correctly. I would recommend hiring an electrician. Watch him or her for next time. What you did is wrong and dangerous.
jrclen is offline   Reply With Quote
Old 03-07-2008, 11:56 AM   #6
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
If a picture is worth a thousand words, here is my five thousand word response to that.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 03-07-2008, 01:32 PM   #7
joed's Avatar
Rewards Points: 12,890
You have a 240 volt service to your garage. Only 240 volt devices can be used. If you want to use 120 volts then you need run a neutral or move the white wire from the breaker to the neutral bus in your main panel and conenct to the neutral bus on the garage. Then you won't have any 240 volts only 120 volts available.
Old 03-07-2008, 07:30 PM   #8
jrclen's Avatar
Rewards Points: 514
Response to what? Turning off the hack circuit? Tell us more oh wise one.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
