240v Receptacle Below Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 07:15 PM   #1
240v receptacle below main panel
I am trying to get power for my compressor. I am okay moving my compressor next to my main panel for the limited amount of time i plan to use it.
Any problems with installing
1. 30amp 2 pole breaker (my box has free space for this).
2. Make a hole at the bottom of my Main Panel and running a 10-2 cable.
3. Installing a " 50 Amp 1-Space 1-Circuit Temporary RV Power Outlet Box" directly below the main panel , Can this be flush mounted ?
1percenter is offline   Reply With Quote
Old 06-18-2012, 07:21 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If you want a flush receptacle, but one of these...
Old 06-18-2012, 07:25 PM   #3
I would prefer something small/flush like you listed however i plan to put this outdoors, do they sell something that would prevent it from getting wet?
Old 06-18-2012, 07:30 PM   #4
Code05's Avatar
Rewards Points: 1,104
Lets's see... a 50 amp receptacle on a 30 amp circuit...
210.21(B)(B) Receptacles.
(1) Single Receptacle on an Individual Branch Circuit.
A single receptacle installed on an individual branch circuit
shall have an ampere rating not less than that of the branch
circuit.
Code05 is offline   Reply With Quote
Old 06-18-2012, 07:34 PM   #5
joed's Avatar
Rewards Points: 11,964
50 amp receptacle is "not less than" the 30 amp circuit.
Old 06-18-2012, 07:37 PM   #6
E2 Electrician
circuit.
It's legal, so many people misread that section.
Old 06-18-2012, 07:38 PM   #7
E2 Electrician
Just buy a weather proof cover.
Old 06-18-2012, 07:42 PM   #8
Code05's Avatar
Brain fart. It happens.
Old 06-18-2012, 07:44 PM   #9
you can tell i am new to this, but thanks i will go to my local home depot and see what i can find.
I would really like to install a subpanel but seeing as my whole garage has cement all around i really don't feel like tearing up cement.
Old 06-18-2012, 07:45 PM   #10
E2 Electrician
Absolutely, I have my share thats for sure!
Old 06-18-2012, 07:48 PM   #11
E2 Electrician
Look for Taymac brand, and your going to want to install that in a two gang box, so look for a 2 gang wp cover with multiple applications.
Old 06-18-2012, 08:06 PM   #12
Thanks! i will use your brand recommendation, i found some at HD which i think will work,
This is probably a stupid question, but does the Electrical Box need to be attached to a stud? or can it just be placed on the stucco and held in place by that?
Old 06-18-2012, 08:10 PM   #13
E2 Electrician
The bell box is for surface applications, you want some deep old work boxes that you can combine to a 2 gang box.
Old 06-18-2012, 08:24 PM   #14
is it okay if these deep old work boxes are plastic? i can't seem to find any made of metal.
Old 06-18-2012, 08:29 PM   #15
E2 Electrician
Plastic will be fine.
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 08:28 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Two sub panels off of main panel OK? brjl Electrical 4 05-29-2011 02:33 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
