240V Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 05:20 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Call an electrician, you sound like you are over your head.
Old 06-29-2012, 09:02 AM   #17
jrclen's Avatar
Rewards Points: 514
I do lots of these. The most cost effective way I have found to do it is to use an aluminum feeder from the house to the remote building. Use a 2-2-2-4 direct burial wire set. Install a 100 amp main breaker panel in the remote building and drive a ground rod out there. Connect these wires to a double pole 90 amp breaker in the house. In the remote building panel, install a ground terminal strip to keep the grounds and neutrals separate and do not bond the neutral strips to the panel. Eliminate the existing circuit to the building.
This should get you started. Just ask more questions as you go, or hire a local electrician.
John
jrclen is offline   Reply With Quote
Old 07-03-2012, 02:54 PM   #18
You, sir, are a gentleman and a scholar. That's virtually all of the info i needed to get started. I realized that the cable run out to my shed currently is not in conduit, but rubber hose instead, so i will absolutely have to dig that up. It's also not going to give me enough power, as it is only a single 12-2 wire on a 20 amp breaker.
Thank you very much for the detailed response and info.
PumpedUpKicks is offline   Reply With Quote
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 09:50 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 05:15 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
