240V Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 06:54 PM   #1
240V Question
Hey gents, i'm wiring up a stand-alone workshop on my property and i want to be able to have access to 240v for my big air compressor and my welder. I'd also like to run a separate 120 line(20amp) for everything else.
The run from the breaker panel in the house out to the workshop is roughly 100-125 ft and i have about 7 empty spots on the panel to add whatever i need.
I'm trying to write out a materials list so i can buy everything i need, but I have never wired up 240 before and i need some help. What kind of wire should i be using for 240 in order to run it that distance? Also, how should i set up the 240 line on the breaker? Am i leaving any factors out of consideration here?
Admittedly, i'm a noob at this, so any help or pointers are greatly appreciated!
PumpedUpKicks is offline   Reply With Quote
Old 06-28-2012, 06:59 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You are going to need a sub panel in the workshop...what size?...couldn't tell you unless you can list the specs of the welder and compressor.
You need to do some research on this. There are any number of threads on this forum for you to check out.
Old 06-28-2012, 06:59 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
First off, is the workshop attached to the main structure or remote?
Old 06-28-2012, 07:05 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
I think thats the answer!
jbfan is online now   Reply With Quote
Old 06-28-2012, 07:06 PM   #5
By stand-alone, i meant remote. It's about 100 feet from the house.
Old 06-28-2012, 07:08 PM   #6
E2 Electrician
at least I don't assume its attached.
Old 06-28-2012, 07:42 PM   #7
So, as i've read a tiny bit, it would seem that i need a sub panel in my shed if i want 2 separate circuits. I'm still unsure about what kind of cable i should use to run enough electricity for a 240 and a separate 120. 10/4?
Old 06-28-2012, 07:43 PM   #8
E2 Electrician
The load will determine the wire size.
Old 06-28-2012, 08:20 PM   #9
DIY staff
Rewards Points: 7,174
Need the size of the welder and the size of the compressor and whether both units will be running at the same time---
Old 06-28-2012, 08:24 PM   #10
The plan was to have the ability to run them both at the same time. Both off the 240v circuit. That's why i wanted to run a separate 120v line for everything else.
I don't have the specifics right in front of me, but while running, they'd both draw somewhere in the neighborhood of 2,000 watts each.
Old 06-28-2012, 08:29 PM   #11
Rewards Points: 1,418
You would run only one feed from the house panel to the shed subpanel. This would consist of two hots, a neutral to obtain 120 volts, and a ground.
Since you mentioned a welder, chances are you would need #6 copper conductors allowing a draw of 60 amps from each of the two hot conductors which would include the 120 volt usage between each hot wire and the neutral. (Are you sure the welder draws only 2000 watts?)
If you already have a feed from house to shed and that is not heavy enough, then that has to be decommissioned. It could be resurrected for lights that are controlled from both house and shed (fed with power from the shed subpanel).
Old 06-28-2012, 08:43 PM   #12
What kind of wiring/cable would you use for the feed?
Not to sound blonde, but where would i need #6 copper conductors? You mean the wiring to the shed would need to consist of #6 copper?
Yes, i already have a feed going out there, which is only rated for 30amps. A basic cable for lights and outlets on a 20amp breaker.
Old 06-28-2012, 10:44 PM   #13
Is the existing feed (one hot and neutral and ground) 120 volts only, or (two hots and neutral and ground) 120 and 240 volts?
For 30 amps max you would have #10 gauge feed wires.
Old 06-29-2012, 03:18 AM   #14
The existing wire gauge is 12/10, I know it's max capacity is 120v
Old 06-29-2012, 06:17 AM   #15
You need to start thinking / talking correctly.
You say the existing wire gauge is 12/10. ???
Which is it? 12 or 10 gauge.
"I know its max capacity is 120v" . Well i'll bet if you look on the wire it says 600 volts...
You can put 120 volts or 240 volts (up to 600 ) on a wire.
Now, how many wires and how they are hooked up determines if the circuit is going to be 120 or 240. (were just talking residential here )
For an unattached garage like that, you should only run one feed to it.
So you would use a '3 conductor with ground' cable. A black, red, and white wire with bare ground, typically.
The black and red to the double pole breaker at the house, the white to the neutral bar and ground to ground bar.
Now you have 240 volts out to the garage sub panel.
You can pull 120 volts off of it by just using the black ( or red ) and the white. Plus ground.
Now the wire SIZE is where it gets expensive.
A little 14/3 cable will get you 240 volts out there. But you are limited to 15 amp breaker.
A 6/3 cable will get you 240 volts also, but you will be able to draw enough amperage to run your compressor and welder and lights . Probably... You need to check machines to see what they draw.
You might want to run 4/3.
And those cables cost quit a bit more than 14/3.
So there is no magic answer. It depends on what you are planning to have running to decide what size wire.
And I agree with AllanJ, 2000 watts seems low for a welder.
jammin06 is offline   Reply With Quote
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
Do you think a tool running at 240v works better than at 120v? Piedmont Electrical 39 07-03-2009 10:50 PM
Question on 240v double pole breaker locations rovers1973 Electrical 10 02-14-2009 06:15 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
